Old 06-15-2021, 05:30 AM   #1
nassih
City & State: casablanca
My Country: morocco
Default Macbook Pro Retina work only with adapter
i have this macbook 2012 model A1425 motherboard 820-3462 work normal with adapter but not working with battery.its show charging and the battery has 134 cycle charge and its detected by the system.
nassih is offline   Reply With Quote
Old 06-15-2021, 05:38 AM   #2
nassih
My Country: morocco
Default Re: Macbook Pro Retina work only with adapter
i have this voltages without adapter in:
PPVBAT_G3H_CONN: 11.38v
PPVBAT_G3H_CHGR_R : 11.38v
CHGR_PHASE :11.38v
Old 06-15-2021, 05:41 AM   #3
nassih
My Country: morocco
Apple Macbook Pro Retina A1425 MLB D1 051-9216 820-3462 (8-8-2012) schematic.pdf
Old 06-15-2021, 05:46 AM   #4
nassih
My Country: morocco
with adapter in i have 12,56v on PPVBAT_G3H_CHGR_R but goes to 11,38 immediately
Old 06-15-2021, 07:36 AM   #5
mon2
mon2's Avatar
City & State: Windsor, Ontario
My Country: Canada
Line Voltage: 110VAC
Battery is probably crap. It is a common issue. Check with a fresh battery from a supplier that will take it back if there is an issue.
Remove the battery and post the same voltages.
mon2 is offline   Reply With Quote
Old 06-15-2021, 09:27 AM   #6
Stephen
Meow Meow MEOW!
Stephen's Avatar
City & State: Atlanta, GA
My Country: United States
Line Voltage: 120VAC 60hz
I'm a: Hardcore Geek
What mon2 said. I recieved NEW OEM batterys with 0 cycles and they were crap. It is most def that bat.
MEOWING IN THE IMPOSSIBLE UNIVERSE!
Stephen is offline   Reply With Quote
Old 06-15-2021, 12:00 PM   #7
nassih
My Country: morocco
ok i dont have another battery but i will check more voltages and tell you tanks for replay
Old 06-16-2021, 06:33 AM   #8
dellxps15
City & State: Italy
My Country: italy
without battery, post volts on battery connector after connect adapter.
dellxps15 is offline   Reply With Quote
Old 06-17-2021, 10:28 AM   #9
piernov
Moderator
City & State: Valbonne, 06
My Country: France
Most batteries for A1425 available on the market are garbage.
OpenBoardview — http://openboardview.org | IRC — #[email protected]
piernov is online now   Reply With Quote
Old 06-30-2021, 01:17 PM   #10
janceth
City & State: panama
My Country: panama
I have a cuestión about this MacBook.
the hardware of the MacBook retina 12" inch 2017 is compatible with hardware of MacBook retina 12" inch 2015
janceth is offline   Reply With Quote
Old 07-04-2021, 12:43 AM   #11
azzidoqsc
City & State: Iasi
My Country: Romania
Can you check what is the voltage of the cells ? Sometimes the laptop battery chip gets locked due to worn cells or over discharged cells (battery stored for a long period). The PFF (Permanent Failure Flag) is set and nothing can be done with that battery unless you unseal the chip and clear PFF.
I usually repair laptop batteries in my free time. If you want to open the battery I could guide you how to try repairing it.
azzidoqsc is offline   Reply With Quote
Badcaps.net Technical Forums © 2003 - 2021
