Old 05-18-2021, 11:04 PM   #1
mgrharry
City & State: los angeles, ca
My Country: usa
Default Acer A515 Not Charging
Acer A515 motherboard, part number DA0ZAWMB8G. Someone tripped over the charging cord and broke the DC jack. Jack has been repaired, but system still doesn't detect charger.
19V is present on charger pin and drain of #1 mosfet but there is no voltage on the gate and source. There is 19v on a small cap near gate. If battery is plugged in, #2 mosfet measures 10V on drain, nothing on gate.
Mosfets are AON6414A. Datasheet https://datasheetspdf.com/pdf-file/7...ors/AON6414A/1
Measuring in diode mode I don't find any short to ground on any of the surrounding caps.
See attached image.
mgrharry is offline   Reply With Quote
Old 05-19-2021, 02:19 AM   #2
mielta
City & State: Neuss
My Country: Germany
Default Re: Acer A515 Not Charging
Hi
measure on the shutresistor (its the one with R01) if there is short to ground
mielta is offline   Reply With Quote
Old 05-19-2021, 05:51 AM   #3
Sametbey
Sametbey's Avatar
City & State: Zonguldak
My Country: Turkey
Line Voltage: 220VAC 50HZ
diagram and sample measurements will help. In order to trigger the N-mosfet at the entrance, it must be 25v at the gate. Check the voltages of the charging chip.
File Type: pdf Acer Aspire A515-51G C5V01 LA-E892P R1A.pdf (1.62 MB, 24 views)
I'm not happy to be so strong. because it's not humanly
Sametbey is offline   Reply With Quote
Old 05-20-2021, 08:26 PM   #4
mgrharry
My Country: usa
No short to ground on R01
Old 05-20-2021, 08:46 PM   #5
mgrharry
My Country: usa
Thanks for the schematic. Unfortunately me and schematics = I tracked down the boardview as well but compared to the Mac board views it's so minimal and disorganized it wasn't much help.
What charging chip are you referring to Sametbey?
Old 05-24-2021, 07:49 PM   #6
mgrharry
My Country: usa
Here are some full size photos showing the entire board top and bottom.
Old 05-24-2021, 08:37 PM   #7
Spider1211
City & State: Morcellement
My Country: Mauritius
Line Voltage: 230VAC, 50Hz
Charging IC is a small black square chip and will have "BQ735" written on it like this: https://www.leakymosfet.com/products...735-735-qfn-20
Find the IC on the board and measure voltage on the following pins and report back:
1. Pin 20 (Vcc)
2. Pin 6 (ACDET)
3. Pin 5 (ACOK)
Spider1211 is offline   Reply With Quote
Old 05-25-2021, 02:07 PM   #8
kiwin
City & State: Saratov
My Country: Russia
You have a broken power connector. It has 3 contacts. ++19 volts /GND and AD_ID. The AD_ID pin is not triggered in the connector. It should short to GND.
kiwin is offline   Reply With Quote
Old 05-25-2021, 03:43 PM   #9
SMDFlea
City & State: York
My Country: UK
Your motherboard is a quanta ZAW , i posted the schematic and boardview -
https://www.badcaps.net/forum/showthread.php?t=96065
SMDFlea is online now   Reply With Quote
Old 05-25-2021, 07:58 PM   #10
mgrharry
My Country: usa
That makes a lot of sense since this happened right after cord was tripped over. I reflowed the 19v pin but maybe the ID pin is busted internally.
Old 05-25-2021, 09:10 PM   #11
mgrharry
My Country: usa
No chip labeled BQ735, but I did locate BQ24780S
https://www.ti.com/lit/ds/symlink/bq...=1621969065294
According to that, VCC is pin 28, ACDET pin 6, and ACOK pin 5.
VCC = 19.16V
ACDET = 0V
ACOK = 0V
Old 05-26-2021, 08:14 AM   #12
Spider1211
VCC = 19.16V
ACDET = 0V
ACOK = 0V
I was referring to the initial attached schematic. Per new schematic provided by SMDFlea, charger IC is indeed BQ24780s.
ACDET should be 2.6V. Check if you have continuity (Ideally from ID pin in charger port) between pin3 (ADP_ID) of adapter input (PJ2) and pin2 of PQ17 . Also measure voltage on pin2 of PQ17 and report back.
Since you mentioned tripping over the cable, pretty sure the ADP_ID pin is the issue here.
Old 06-18-2021, 12:11 PM   #13
kjchatman
City & State: spring lake/ north carolina
My Country: united states
I have this board and it's dead. i'm wondering if this large chip near the charging port that circled red in the pic is a fuse. it has no continuity and is shorted to ground on one side
kjchatman is offline   Reply With Quote
Old 06-18-2021, 04:06 PM   #14
mon2
mon2's Avatar
City & State: Windsor, Ontario
My Country: Canada
Line Voltage: 110VAC
No. That is a bulk ceramic capacitor. One side is expected to be to ground.
Often, fuses that are surface mounted (like this part) are white in color for the body of the component.
For your repair attempt, start with where the logic board is powered. Then check that the power supply is making it from the external power adapter -> to the power connector -> to the mosfets that will enable / disable to charge up the local battery, etc.
Start with the meter in DC volts mode with black lead to ground. Red lead onto the DC power in jack. Guessing that for this laptop, the DCIN voltage is around 19 Volts and is a round barrel (coax) jack with center pin positive.
The more recent designs are with USB Type C power adapters.
mon2 is offline   Reply With Quote
Old 06-18-2021, 07:01 PM   #15
kjchatman
i'm getting 19v on pin 1 of bq24780s. shouldn't i get the same on pin 2?
Old 06-19-2021, 08:43 PM   #16
kjchatman
19v is actually on the vcc pin of bq24780s.
Old 06-20-2021, 03:20 AM   #17
Sephir0th
Sephir0th's Avatar
City & State: Wangerland
My Country: Deutschland
Line Voltage: 230VAC 50Hz
I'm a: Hobbyist Tech
Share the actual issue of your Board, History If available and which measurements you did so far before proceeding with anything.
Sephir0th is offline   Reply With Quote
Old 06-29-2021, 11:40 AM   #18
kjchatman
it wasn't detecting the charger. I removed pq9 to solve the issue
Badcaps.net Technical Forums 2003 - 2021
