Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Laptops, Portable, and Mobile Devices
Thread Tools Display Modes
Old 03-10-2021, 07:05 PM   #321
rccrasher65
City & State: west mifflin
My Country: United States
I'm a: Knowledge Seeker
Default Re: Hp Probook 455 G3 DAX73AMB6E1 blinking charge light, not turning on
Quote:
Originally Posted by BlueMidnight View Post
Alright, hope you have a smooth recovery.
Challenge accepted
Thank you, much appreciated. I'll try to get back at as soon as I can.
rccrasher65 is offline   Reply With Quote
Old 03-22-2021, 04:59 PM   #322
rccrasher65
Quote:
just checking in, still not able to do much!
Old 03-22-2021, 05:04 PM   #323
SMDFlea
City & State: York
My Country: UK
Hope you get well soon, you can`t do much without your health,that has to come first .
SMDFlea is online now   Reply With Quote
Old 03-25-2021, 03:38 PM   #324
rccrasher65
Thank you!
Old 05-21-2021, 02:51 PM   #325
rccrasher65
Quote:
well after a long shoulder recovery, I think I can get back at it with programming, mod was done. If my friends out out there, give me a holler!
Old 05-21-2021, 04:45 PM   #326
BlueMidnight
City & State: Chicago, IL
I'm a: Professional Tech
Welcome back. Hope you're feeling better. Please continue from post 316.
BlueMidnight is offline   Reply With Quote
Old 05-22-2021, 02:04 PM   #327
rccrasher65
Feeling much better, still trying to get winzip to open that rar file, once I get that things will start I guess. I have no idea why I'm having such a hard time with that. I think I might have to subscribe to winzip for it to open. It is certainly not opening any other way I've tr. Suggestions.
Old 06-11-2021, 08:53 AM   #328
rccrasher65
I finally got those files to open, and are in a folder. I guess I'm ready to program that reader. Any instruction on how to do that. looked on y-tube, can't understand most of them. Thanks
Old 06-11-2021, 09:39 AM   #329
Stevedb
Stevedb
City & State: Schendelbeke/ East-Flanders
My Country: Belgium
Line Voltage: 240v ac
I'm a: Hobbyist Tech
Hi
You must just open colibri and detect the chip. Then just read it then open the file and write.
https://youtu.be/cDek8OnoyaA
Good luck
Best regards
Steve
Stevedb is offline   Reply With Quote
Old 06-11-2021, 05:10 PM   #330
BlueMidnight
And you can try it out on one of the other boards you have so you don't have to worry about making mistakes. Try connecting that little clothespin-style clip to the chip so you don't have to desolder anything. Make sure the red wire goes to pin 1 on both ends.
The first step is always to press the "ID" button to detect the chip model. It will list what model it found in the text box on the left. Make sure it matches the actual chip.
Next, do some practice reads and writes. Click the read button and make sure data from the chip shows up on the right side of the window. Then, without closing the program, write to the chip. The write button will always write the data that is showing in the window. So, in this case, it will write the data it had just read in the previous step.
Practice that a couple times.
Next, try to save a backup of a chip:
1. Open program
2. Click ID
3. Click read
4. Click save (second button from the left) and choose a file name and location you will remember later
Finally, try writing from a file:
1. Open program
2. Click ID
3. Click open (first button on the left) and select the backup file you just made
4. Click write
Once you are comfortable with all of the above, you can try using the real motherboard. Read the chip and save it to a file. We'll continue from there when you reach that point.
Old 06-12-2021, 05:31 PM   #331
rccrasher65
1. Open program
2. Click ID
3. Click read
1. Open program
2. Click ID
4. Click write
Yea it will definately be a while, completely lost. So I do not actually have to install anything on the reader, just put it into my laptop, connect to board using the clip cable, open the calibri program, and try to read chip?
Old 06-12-2021, 05:49 PM   #332
BlueMidnight
See my previous post and the other posts it links to. You have to connect the programmer to the PC, install the Windows driver, connect the programmer to the chip on the motherboard, and run the programmer software.
Old 06-13-2021, 02:05 PM   #333
rccrasher65
I'll need some time to figure this out. I'll get back to you when I know what I'm doing with all this.
Old 06-13-2021, 09:38 PM   #334
rccrasher65
I went to open and install drivers from the file, and its says file not found. Tried both programs same thing file not found.
Old 06-14-2021, 08:04 PM   #335
rccrasher65
what file actually contains the driver. When I plug reader into usb port it shows up on my devices installed. Does that mean I installed the driver? PC recognizes the programmer, from what I'm seeing. I didn't try to connect a board yet. Still don't know if I installed the driver.
Old 06-18-2021, 07:49 AM   #336
rccrasher65
Bump
Old 06-18-2021, 08:05 AM   #337
Stevedb
Stevedb
My Country: Belgium
Hi
Normal you got an notification if the programmer is connected. Underneath the screen.
Then you know your driver is installed and pc recognised the programmer.
Regards
Steve
Old 06-21-2021, 05:48 PM   #338
rccrasher65
Quote:
Originally Posted by Stevedb View Post
Hi
Regards
Steve
what file is the driver in. when I click on the one that says it, its says that the file is not found.I do believe there are 5 or 6 files in that Cipri programmer file. I don't know if I'm making Cense here.
Old 06-21-2021, 06:18 PM   #339
BlueMidnight
Inside the main "Colibri_CH341.rar" archive, there is another archive named "CH341PAR drivers.rar". Inside that archive is a setup.exe program you can run to install the drivers.
Old 06-21-2021, 08:46 PM   #340
rccrasher65
my setup. exe program says driver install failure when I try to install drivers.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2021
Powered by vBulletin ®
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
