Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Laptops, Portable, and Mobile Devices
Thread Tools Display Modes
Old 06-07-2021, 04:38 AM   #1
Andreasbest
City & State: Around the country...
My Country: Hellas ( Greece )
I'm a: Knowledge Seeker
Exclamation Dell Precision 3510 completely dead
Hello.
Got a Dell Precision 3510 dead with burnt SIC530 mosfet.
Some copper traces are gone from the heat, 6, 7 and 8 pin are the same (Vin) and this is the easy part but it also lost pin 3 (N.C) and i'm not sure if and where i can bridge it.
I'm not sure if it's worth it our time that's why i ask you first before i order the mosfet.
Please check schematics and datasheet of SIC530 and let me know.
Thank you in advance
File Type: pdf 11009_LA-C841P-Latitude_E5470_E5570_Precision_3510-ADP80.pdf (5.97 MB, 71 views)
Andreasbest is offline   Reply With Quote
Old 06-07-2021, 01:43 PM   #2
Spider1211
City & State: Morcellement
My Country: Mauritius
Line Voltage: 230VAC, 50Hz
Default Re: Dell Precision 3510 completely dead
Hoping it did not fry your CPU, you could attempt to repair it. I would also replace the other components connected to it. Pin 3 is NC (Not connected), just leave it as is. Make sure to clean the soot properly before soldering on new components.
Spider1211 is offline   Reply With Quote
Old 06-07-2021, 02:31 PM   #3
Andreasbest
Really? Now that's good luck.
What other components you mean?
Old 06-07-2021, 04:16 PM   #4
Spider1211
The resistors (4R7, etc) and capacitors etc.
Old 06-11-2021, 10:19 AM   #5
Andreasbest
Quote:
How can i check if there is a shortcircuit that cause mosfet to burn?
I think mosfet don't explode on their own, correct?
Old 06-11-2021, 10:33 AM   #6
Spider1211
There are many reason as to why electronic components fail. MOSFET handle higher currents and are more likely to fail than components carrying signal (low power).
In your case, the MOSFET (both high and low drive) and the driver itself is all in one chip. With the chip removed, measure resistance to ground on Vin (pin 6). VSHW (pin 8) will show a low resistance because of the CPU which is normal. You should measure resistance to ground on all pins actually.
Replacing the surrounding components, especially the way the chip has failed, is good practice and as well as a precaution since you cannot be sure it did not sustain some form of damage which may not be immediately apparently.
Old 06-17-2021, 02:50 AM   #7
Andreasbest
Hello!
You mean these that i marked in red (attachment)?
I'll check resistance as soon i return to bench, meanwhile i order the MOSFET (5x just to be sure)
Old 06-17-2021, 04:09 PM   #8
Spider1211
Yes. Also, although the other nearby capacitor and resistor looks OK, I would still replace them if possible.
Check the tracks properly before soldering new parts to make sure they did not break/crack, etc.
Old 07-26-2021, 10:06 AM   #9
Andreasbest
Hello Spider!
Finally the MOSFET lot i ordered is here so i can proceed with this.
So the Vin has only 3Ω to ground and full continuity.
Should i proceed to rest measures or the problem is here?
Old 07-26-2021, 11:41 AM   #10
Spider1211
VIN (pin 6) of PU602 you mean? You are measuring with the IC off, correct? If so, 3ohm is too low and is indicating a short on that line.
Remove PL602 and/or PJP601 if present and measure resistance to ground on both sides (pin 1 and pin 2 of PL602).
Report back your readings.
Old 07-26-2021, 01:08 PM   #11
Andreasbest
Yes pin 6, 7 and 8 (the same trace) of PU602, with burnt IC desoldered like in picture.
I can confirm left side of PL602/PJP601 (side of MOSFET) is shorted to ground.
Old 07-26-2021, 01:22 PM   #12
Spider1211
6, 7 and 8 of PU602 are not the same. 7 is ground so short to ground here is obvious, pin 8 goes to CPU via PL603 and therefore low resistance is to be expected but pin 6 is VIN and should definitely not be low resistance.
Mosfet side (pin 2 of PL602) is around 3ohms, correct? What about pin 1?
Old 07-26-2021, 01:26 PM   #13
Andreasbest
I measured according to datasheet but propably is reserved?
Old 07-26-2021, 01:31 PM   #14
Spider1211
My bad, I was referring to schematic. What is the resistance on Pin 1 of PL602?
Old 07-26-2021, 01:34 PM   #15
Andreasbest
pin1 15Ω
Old 07-26-2021, 01:36 PM   #16
Spider1211
That's low. Just to confirm, you did remove PL602 and PJP601 yes?
Old 07-26-2021, 01:37 PM   #17
Andreasbest
Yes pl602 is removed (pjp601 under pl602 is not soldered at all, pure copper)
Old 07-26-2021, 01:39 PM   #18
Spider1211
Remove PJP603 (make sure you clean the pads properly) and measure resistance pin 1 of PL602 again.
Old 07-26-2021, 01:47 PM   #19
Andreasbest
with pjp603 removed and cleaned 14.7Ω
Old 07-26-2021, 01:53 PM   #20
Spider1211
Something is pulling +PWR_SRC down. From the picture it seems the soot extends to QV1. Try removing it and see if that changes anything. Otherwise you need to check around for damage.
Maybe try disconnecting +PWR_SRC jumpers on different power sections and see if that changes anything.
There is also the issue of low resistance (3ohms as you mentioned) on pin 2 of PL602.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2021
Powered by vBulletin ®
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
