Tannoy Reveal 6D
    Re: Tannoy Reveal 6D
    Hi there,i have a pair of 6ds that seem to have done the same thing over a year ago... Sound appeared to become distorted from one box. Then the next day it was gone altogether.. I did however manage to get the schamatics out of tannoy..so was able to start tracing the fault. As there was now no warranty support for thia product i pulled the apart and by a process of elimination, think i've narrowed the fault down to the amplifier board... But hit a brick wall when the caps appeared to test okay...
    I'll sit down with this thread,the schematic and the amp module and see if i can't find the problam...
      I'm sure you'll get plenty of support from here if you get stuck.
      I would start with gunk removal first and most importantly the stuff that's gone hard.
      Good luck
      Midibob
        Shock, horror.
        One of the tweeters has now gone open cct.
        As these have only been used in the studio as monitors they've never been played loud so I'm a bit miffed.
        At about £50 for a spare it's not worth replacing as the speakers didn't cost that. I'm hoping to have a go at repairing it as it could just be a fractured wire to the voice coil. Problem is I can't get the flipping thing apart.
        Even under the microscope it's difficult to see how it separates.
        Anyone had a go at one of these?
        Midibob
          Managed to get it apart in the end but the bad news is the voice coil was toast.
          Midibob
            I recently experienced the same problem with one of my 6D monitors, out of the blue a loud pop then a constant hiss after switching it on and no sound thereafter. It's a real shame as they've been absolutely flawless since I bought them new nearly 8 years ago.
            Midibob, your tips have been invaluable. So far i've managed to disassemble the amp and remove most of the dried brown glue from the PCB, though I've no electrical testing gear so i'm hedging my bets a bit that it's R18 that's faulty (I couldn't even see it on the board at first, it was hidden under so much glue!). I'm going to replace it and see what happens; if that's no good there's a local guy I know of who fixes up sound equipment.
            Btw, I don't know if you've found one yet, but I came across this 120 Ohm 5W radial resistor from Farnell: http://uk.farnell.com/multicomp/mcpr...-5w/dp/1737463
            PS: A tip for others for opening up the speaker - I eventually managed it by using a small flat-head screwdriver inserted between the corners of the metal back plate and the cabinet to gently prise them apart.
              Yep, I did see that one at Farnell. If you look closely you'll see that it's US stock only and it's £15.95 delivery charge to the UK!!
              Hope you get yours sorted. You'd think there must be something that would shift that gunk without damaging anything else but I've never found anything. No substitute for a bit of elbow grease and a scraper
              Good luck
              Midibob.
                Well, on the other hand, you COULD try a "normal" axial 5W resistor, like
                http://uk.farnell.com/multicomp/mckn...5ws/dp/1903932
                and just bend one of the legs so it's parallel with the body Think of a J or (asymmetrical) U shape. If you wanna be really "pro" (or "paranoid"), you can slip some cable insulation on the bent leg, or some suitably small-diameter heatshrink.
                And if that bent leg needs extending, a piece of wire or a thicker resistor/cap leg soldered on, can work wonders
                Should be just fine, since "even" the originals seem to have been tacked / "hacked" on there with all that glue...
                  Hi Midibob,
                  I went out and bought a multimeter today and did some testing around the board. It looks like it is R18 and L1 that have gone; both read open circuit. I've swapped out R18 for another 7K5 resistor, but obviously L1 is another matter. As Khron666 has pointed out above, would an axial resistor do in it's place (obviously ceramic still)? Did you use something similar for your repair given that you couldn't find the radial type?
                    If it's rated for 5W, i don't see why it wouldn't work Of course, you might wanna tack it in place with some sort of heat-resistant adhesive.
                    A drop of RTV rubber, perhaps? I seem to remember silicone's slightly acidic when curing...
                    http://www.mitre10.co.nz/how_to_guid...icone_sealant/
                    Yep, the bathroom sort seems to be indeed acidic
                      Thanks for the tips Khron, I'm a bit of a noob to electronics. I normally deal with stuff 'inside the box' (web developer by trade!)
                      My only concern with using a different type of resistor is how it would affect the audio, as I bought the monitors as a matched pair. Would it have any effect on the frequency response or sound character using wirewound over metal film?
                        Nope, these resistors are on the power rails, just before the voltage regulators that drop the voltage from the "high" (whatever voltage the power amps are supplied at) down to the +/-15v needed for the small-signal stages (S/PDIF receiver, digital-to-analog converter, and the opamps that make up the crossover and so on).
                        Unless you're one of them "audiophool"-types, i *seriously* doubt you'll notice any non-auto-suggestion-induced differences But since you actually got studio monitors, that pretty much rules that out
                        Not to mention that such power resistors rarely (if ever) come in tolerances tighter than +/-5%, so... Potentially, you could have a ~10% difference between the resistors in the two monitors, straight out of the factory
                          Haha, no I ain't no 'phooool I'd just read that wirewound types had less noise / more inductance but I guess if they're not in the signal path it's not going to matter. Good point about the tolerances too.
                          I'll get some on order and hopefully have the monitor fixed up soon. Thanks again!
                            Glad to have been of assistance And yeah, i definitely like to "keep my feet on the ground" (ie. no "phoolery" here either )
                              Well...good news and bad news. The good news is I replaced L1 with a similar type 120R 5W resistor I found on eBay, put everything back together and the monitor came back to life! The bad news... after about five minutes of listening the sound then faded out to nothing
                              While it was working, the sound of the repaired monitor was a few dB quieter than the good one. So I raised the trim pot to about half and all seemed well, played a few reference tracks, all good. I fiddled with the trim pot again after about 5 mins of listening and that was when the sound faded and wouldn't come back.
                              I've taken it apart again and tested the pot and that seems ok, gives readings of 4.8K at its lowest and 3.2K at its highest. So, i'm at a bit of a loss as to what to do next. Anyone have any ideas what it could be?
                                Could be a few things.
                                Don't forget the DIL switches as they can go intermittent. Just flicking them up and down a few times seems to clear them for a while. (At least a year in my case).
                                Otherwise you'll need to dig a bit deeper. Are the caps OK? This has already been well documented.
                                Make sure both the supply rails are still good.
                                Good luck
                                Midibob
                                  You know, it could well have been the switches. I reset them just before when i'd taken the monitor apart again. Now i've put it back together, all seems well! Equal levels coming from them both with the same settings
                                  I've been listening for a good half hour now with no problems, I don't think i've ever enjoyed hearing them so much!
                                  Thanks again, Bob!
                                    I know I'm replying to a relatively old thread but this has been a project on my list for a while. I found pretty much no information on this a few years back -- sat down to revisit the issue this weekend and this thread was a great find.
                                    I have a set of the Reveal 6D. A couple years back, L1, the 120R 5W resistor failed and did a pretty good job of charring 7600 1556 amplifier PC board.
                                    I unsoldered all of the components on the damaged board, cleaned up the brown glue and made a couple of high-resolution scans of the bare board. My goal is to get a B&W image to use to etch a new board and populate with new (already on-hand) components to resurrect the speaker.
                                    I've been slowed down significantly (years?) at the Photoshop stage -- taking the green PC board image and hand converting the green traces vs green glass to a b&w image. Photoshop filters and fill levels only go so far. Doing it right has been time consuming at best. I've been slow finding time for this with work and family commitments and other low-hanging-fruit projects.
                                    So I'm curious if anyone has arrived at a similar point in their repair -- re-making the board?
                                      Hi TJC,
                                      Can't say I've ever done it that way although not a bad idea.
                                      Normally I'd use Eagle CAD which is pretty time consuming to try and get an exact replica.
                                      Just a thought and I'm no expert in image manipulation, but is not possible to differentiate the traces through level of intensity rather than colour? Perhaps a different package like Inkscape. Only guessing here of course.
                                      Good luck.
                                      Midibob
                                        Yes, it should be possible to differentiate traces via intensity levels, but the board is almost entirely the same shade of green. Levels that work in one part of the board completely botch the rest. My wonderful wife -- who deals with Photoshop and InDesign professionally -- spent way too much time trying to find a way to make it work.
                                        Here's what I have, scorching and all:
                                        https://www.dropbox.com/s/4dp6atwzar...nnoy_amp_1.png
                                        https://www.dropbox.com/s/tc0axbl9d1...nnoy_amp_2.png
                                        So I think it's just a matter of finding time to finish doing it the hard way.
                                        And then make two, because with my luck the other one's going to flake out the same way!
                                          Hmm... I might sound like the adventurous type, but seeing as that resistor only has connections on the bottom / solder side of the board, i'd just re-do all the (now) non-existing connections with a few resistor legs (or a strand or two of CAT5-wire ) and great care
