Like the title says, what's the point of all the glue I see strung over EVERYTHING inside of most PSU's. Seems like the manufacturers go a little glue-happy at times!
why all the glue in PSU's?
Re: why all the glue in PSU's?
My dad thinks so that loose components in power supplies will survive shipping without being knocked off. There are lots of glue around caps with some power supplies, and that drives me nuts.My gaming PC:
AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
ASUS M4A77TD AMD 770 AM3 Motherboard
PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
ASUS Xonar DG 5.1 Channel PCI sound card
Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
Antec Three Hundred Mid-Tower Case
Microsoft Windows 10 Pro 64-bit
Microsoft Windows 7 Ultimate SP1 64-bit
The reson coils and caps are covered in glue is to eliminate the high-pitched tone they can otherwise create which is very annoying
It's common for older TV sets to have this problem; the glue has after the years gotten solid and thus does not prevent the multi kilohertz signal from causing for example the ferrite core in a coil to start moving and creating noise..."The one who says it cannot be done should never interrupt the one who is doing it."
The Enermax EG301P-V 300W PSU I have lying around my house doesn't have any glue on the inside!My gaming PC:
The glue is for mechanical stability, on lytics and on the toroid-core inductors. The switch frequency for modern switchers (late 70s onward) is above 20KHz, i.e. not audible (many current switchers operate above 100KHz).PeteS in CA
