Macbook A1466 mb 820-3437 keyboard not work
    Hello all,
    i have that laptop with keyboard problem.
    The keyboard is not working, i have already replaced the whole palmrest but still i have problem.
    Checked voltage on J4800 keyboard connector and they are presents.
    Any help?
    Thank you to all
    Re: Macbook A1466 mb 820-3437 keyboard not work
    Hi
    Your touchpad is could be bad or corrosion around connectors
    Be aware that there are 2 different versions of keyboards in these models and you may need MRI tools to flash the new trackpad to match the keyboard. Otherwise the function keys may not work.
    Techman1025
      Originally posted by techman1025 View Post
      Hi
      Techman1025
      Thank you very much for your reply.
      Where i can find more info about thar MRI tools?
        techman always showing lots of knowledge
        how you doing mate ? hope that good !!
          hello pls check R4844 =0 if it more than 0 replace it
            thank you, yer R4844 is 0 ohm
              Hi
              Maybe cable in dead doing a ohm test on both ends to confirm good or bad again inspect connector reflow if needed . Also this might help: http://advancedreworks.com/forum/sho...lt-639-28.html
              Techman1025
                Hi
                Techman1025
                cable is new, i have eplaced all palmerst with cable. Also i have exchanged circuit with where is located nand flash. The problem seem on motherboard, but i checked it with microscope and seem all ok .
                  Solved:
                  client have replaced palmrest with wrong version
                    Hi
                    This is why you never listen to what other have done Like i said in the early post(2 different versions of keyboards in these models)
                    Good job
                    Techman1025
                      Hi
                      Good job
                      Techman1025
                      No no, your alert opened my eyes. Thank you very much.
                        Please, where i can find more info about thar MRI tools? Thanks.
