I have got this projector(pj) for free, and I'm trying to fix it.
I did not get help in other sections on this forum, so I'm trying my luck here as well.
The pj, has three LEDs(Lamp, Power and Temp) that should indicate, what is the problem with it. In my case, none are on. The only LED, that blinks(very dim), is the power button, which is not included in any troubleshooting info.
I have took the projector apart and I have measured some voltages.
12.65V and 3.3V are there in the secondary output(CN701 connector).
I also have 171V at the main capacitor, after the rectifier.
What I don't have, is the 385V that should supply the ballast for the bulb.
Also, I have measured two more voltages in the primary side, 21V PFC and 19Vcc and these are much lower. 15.4V PFC and 11.2Vcc.
I can't find datasheet, for STR-W6262A, so I'm stuck with the repair.
I'm attaching the PS schematic(elektrotanya, has the full sm) and the datasheet for the FA5502M IC.
I'm guessing that somehow the PS has to be turned on, right? I don't know how, though. Should I use a resistor(what size ?), between 3.3V and pin #14 at the CN701?
Any help, would be appreciated.
Tibor
Tibor
