LG 60PB6650 - Bad ZSUS (3.8v to YSUS instead of 16v)?
    Re: LG 60PB6650 - Bad ZSUS (3.8v to YSUS instead of 16v)?
    One more bump.
      If you checked the voltages on the regulator ic's on the control board, and they are what they should be, you need a scope to check if anything else is operating, without that you would need to replace the control board.
        Thanks, RJ. I'm going to look into replacing the control board before I send the YSUS out for inspection.
          UPDATE: Sent the Y-Sus, Y upper, and Y lower out to a somebody on ebay (https://www.ebay.com/usr/asa.vd.pc) and they said the boards are fine. Onto the next board, probably main logic.
            Did you ever figure out what was wrong with your TV? I have the same TV and it has just gone bad. I turn on the TV, red stand by light goes off but there is no sound or picture. I don't get a blinking light on the logic board either.
              Hi everyone?
              I have L.G. 60PB6900 but is with the same issue...
              I changed Y-Sus and Z-sus, but still 18v. are not present...
              The green light doesn’t come on...
              Did you find a solution for that issue....
