sorry retiredcaps every site is different. by "crossposting" do you mean posting info in more than one place?
Yes. The identical post showed up in another badcaps.net forum.
Your picofuse is bad. Before you replace the picofuse, you MUST (MANDATORY) resolder all the inverter transformer pins otherwise the picofuse will likely blow again.
The c5707 transistors and fu9024 fets may also be shorted out.
--- begin sig file ---
Are the c5705 transistors and fu9024 fets the ones with the heat sinks? There's slight discoloration on the board beneath them. I don't see these ID's marked anywhere on the board. All the transistors are marked with a Q and C for caps at least here in Canada. See pg 61 pic 0107. Also which are the inverter transformers? Sorry about the picture quality, cheap camera = cheap pics. BBT.
Green = inverter transformers.
Red = c5707 -> the part number c5707 is written right on the chip
Yellow = fu9024
Normally, we would reference PCB board designations, but your pictures are so poor, it is impossible to read them. If you look at post #12 from PlainBill, he might have listed all the board designations from his own personal notes.
Set your multimeter on 200 ohms. Any reading below 30 ohms suggests a shorted component.
The c5707 and fu9024 can be tested "in circuit". Just test every possible combination of pins for shorts. That is, measure the ohms between pin 1-2, 1-3, and 2-3.
If any of the components are bad, you can order "c5707 kits" on ebay for about $4 to $5 CDN.
