My out of warranty UA46D5500 46" Series 5 LED is having this dented line as shown below, any idea how to fix this?
Dented line
Re: Dented line
No these are part of the LCD panel itself. Not replaceable. If it's just one line in its not effecting anything else I would just leave it as it is as it is most likely going to get worse if you mess with it. Unless it goes out completely.
If it's bothering you and you want to try to repair it you would have to remove the plastic bezel around the LCD screen and take pictures of each side of the LCD panel.Did I leave the soldering iron on?
Re: Dented line
Originally posted by freakaftr8 View PostNo these are part of the LCD panel itself. Not replaceable. If it's just one line in its not effecting anything else I would just leave it as it is as it is most likely going to get worse if you mess with it. Unless it goes out completely.
