Samsung was dropped. see pictures. Picture fades to the left.
Samsung un40mu7000f dropped, picture right to left darker
Re: Samsung un40mu7000f dropped, picture right to left darker
Need to do some disassembly to get to them, remove bezel etc., some can be "fixed" by finding a way to apply some pressure on the tab with a shim of some sort, try flex the frame a bit see if the display changes any, not too hard, don't want to crack it.
Bit of an example there, if you get to the tabs and applying a little pressure and the picture doesn't clear up, then a bad bond is not the problem. Guess just start with taking the back cover off the problem may be obvious, there's more detailed videos, just a matter of finding them, this one gives you the general idea: https://www.youtube.com/watch?v=8l5ORKjQF5ULast edited by nomoresonys; 04-05-2020, 09:14 AM.
Could try the "cut tape" method first, just for fun, see what happens, sometimes you have to play with the size of the tape to get it just right: https://www.youtube.com/watch?v=7TT8QYeN1s8
