Shutt down issue Win 10 Updates 1709?
    Hi guys; i updated to 17.09 version and it screwed up my shutdown the normal way,i went through remote assistant with 4 CS people but none was able to fix the issue,i had this issue before when i reinstalled system win 10, and one of the MS CS assistant was able to fix issue by changing power option from Balanced to High performance setting ,but this time that fix was not successful,
    so i gave up and i had in my scrap an HDD with win 10 installed and swapped it and made updates to 1607 and now the shutdown is fixed.although when i go to updates it states that 1709 is ready to update,screw them i'm not going to click get started. i also changed setting per instructions here;
    https://www.computerworld.com/articl...nstalling.html
    Re: Shutt down issue Win 10 Updates 1709?
    Hi guys update on the HDD that had MS 1709 updates i just followed these instruction and rolled back to the previous version 1703 and now shutdown issue is gone,for someone that will have issues with Windows 10 Fall Creators Update have a weak to be able to roll back.
    https://www.youtube.com/watch?v=Wl0hvE9JNqY
      What's the issue with shutdown? I've encountered a few issues with the Creators Update where the system would bluescreen upon going into sleep mode. Changing the power plan to high performance would prevent this and act as a workaround. I was unable to identify the driver that was causing the issue and a fresh reinstall of windows seemed to fix it. Is there anything coming up in the Event viewer?
