(LF461EM4) Initially this 46" LCD was shutting down on me after the Emerson logo and channel display. Through the info of another thread here I decided to look at the backlighting and found that the center row of LEDs were out (LG branded). Bought a Samsung branded replacement on eBay and it works. It no longer shuts off with a blinking front LED sequence.
However, at some point during disassembly or reassembly of the front panel I must have done something because the display no longer shows anything. My first thought was I damaged some part of the LCD or connectors...but then I thought I should listen for audio on an input source to verify. Plugged in the audio/video RCA leads from a game console and cycled through sources (without visual) and I didn't hear anything coming through at all. The only sound change I hear is the slight change in pitch from the transformers on the PSupply board when cycling the source button. I also see my backlighting change brightness slightly when cycling sources.
At the supply board I have what I assume is normal voltage for the 21v power on and the 3.3v standby/always on. I haven't really checked anything on the main board because I'm not sure what I should be looking for. It's definitely getting voltage though. Also I had a small crimp in my cable from main to the T-Con(?) but it's no worse the the folds from the factory. I started checking continuity on that but kinda gave up after the 10th pin.
Initially I was just going to order a new main board but I had a a hard time finding one...which the LEDs were the primary issue anyway. Kinda back to where I started but a different problem. I see some people offer online/mail in repair services for these boards if that is the issue.
Any advice for troubleshooting and testing would be appreciated. Hoping I can salvage it and put it upstairs as a game and movie TV for me and the kids. Sorry for the essay, I like to be descriptive and usually find that putting all the info out there helps get the problem solved quicker.
PSupply board: BA3AU0F0102
Main: BA31T0G02013
Starting Serial # DS2
And yes, I'm aware it's a cheap unreliable off-brand...but I like to fix things if it's worth it.
Main: BA31T0G02013
