Power adapter from Apple Time Capsule - 0V at output
    Hello! I'm not very experienced technician… Just trying to repair power adapter from Time Capsule. Maybe anybody have experience in these units?
    This power adapter must output 5V and 12V. But now it outputs 0. I made full recap. Also, I checked voltage at output diode bridge - it's DC 220 V, so diode bridge is working.
    I don't have scheme so I don't know what to check next… So I'm ask maybe anybody know what the most possible can be broken (if no capacitors) in such power adapters. Manufacturer - Flextronics.
    Some photo attached. Thanks for any help!
    Re: Power adapter from Apple Time Capsule - 0V at output
    Please can you update your profile with country and mains voltage.
    220DC doesnt sound correct
      220V DC at the output of the bridge rectifier would be correct for 220V AC input. I would desolder the main switching transistor and check that next. It should be the device bolted to the aluminum heatsink.
        220VAC in put to the bridge, the output will be (220VAC x 1.414) - two Diodes Vf drop, you should have about 310VDC on the main filter cap (measured directly at the two legs of the cap.
        So verify the AC and DC voltage readings again.
          Thanks all, yes, the output on the main filter cap is about 310 VDC (measured directly at the two legs of the cap).
          The input is 220VAC, like in any country in Europe.
          370forlife, is it possible to check main switching transistor, if I only have simple tester? I've heard this maybe FET transistor, so I afraid to damage it during testing.
            Post good clear straight shots of both top and bottom side of the board, it can be as simple as bad start up cap (the small electrolytics cap next to those two 450VDC filter cap) in the primary side.
            The power MOSFET mounted on the heat sink on the primary will usually failed shorted circuits which will cause the main fuse to blow, but since you are getting the DC on the main cap, the main fuse is OK.
            You can try heating that start up with hair dryer to see if the circuit will start up if the cap is not too far gone, you can also measure the DC voltage at the two legs of the startup cap, just be real careful since you will be working in the deadly primary side of the circuit.
              I have made good (good, not perfect) quality photos of board. Also, I added some comments. Attach them here.
              As I understand, I need to try heat up small electrolytic cap (in red circle on my picture) during start up to see if the board will work under heating?
                That is the start up cap, I would replace it (try heating it to see if the power supply will start up), that device mounted on the heat sink is the power MOSFET which drives that yellow power transformer.
                Also take the DC voltage reading right at the two legs of that start up cap.
                P/N of that SMPS IC U6?
                  I tried to measure voltage on start up cap, it changes between 5 and 15V, like on the video (scale on this video is 50V): http://www.youtube.com/watch?v=aoSz1As3iI4
                  Also, I tried to heat up this cap, but this not help. I will replace it on weekend, when I'll be at radio-parts market.
                  P/N of SMPS IC U6: 1271AH PASM
                  Thanks)
                    Try to get a low esr cap panasonic fr fm or fc or nichicon or rubicon equivalent - are any of those available at reasonable cost?
                      We have only "CapXon" on market, so I'll buy what found. Cost for electrolytic capacitors is more than reliable on our market. From 10-20 cents for small caps to $2 for very big.
                        I replaced start up cap, but this not helped. So, all electrolytic caps are new at the moment.
                        Now, I think to look at PWM controller NCP1271AH, this is 65kHz PWM, I found datasheed for it (attached if someone in future will look for it). I bought old used simple oscilloscope (will arrive at weekend), so I can post more info after inspection with oscilloscope
                        If anybody have something to say - please post, I do further investigation at weekend and post results.
                        If anybody have simple block diagram which explains principle of operation of Switching Power Supply please post.
                        Thanks all for participation!
                          Since you will be working in the primary (HOT) side of the circuit, make sure to plug this board into the Isolation transformer before attaching your scope probes to the board.
                          Trying the IC will be a good idea.
                            Can you please explain what is isolation transformer?
                              http://www.hammondmfg.com/171.htm
                              You need to isolate what you are working on from primary power.
                                What the actual fuck, Apple charge how much for their time capsules and you don't even get half decent caps? What a joke.
                                  I have not understand what you want to tell, I think you joke about big caps? I just soldered what I found at market, for testing, when I'll found the problem and PSU will work, I'll found more compact caps.
                                    It's not that they're big, it's that CapXon is one of the worst brands of capacitors in the world.
                                      Ok, but we don't have other (only "Chang" but I think it even worster china brand)
                                      if this project will work, I'll order something via eBay!
                                        No, I mean Apple use CapXon capacitors which are terrible. I have no complaint with yourself -- sorry if it came across a little harsh, I'm just disappointed that a company which is well known for charging large amounts for what essentially amounts to shinier products than other companies, cannot at least put in good components.
