3300uf 6.3v for xbox
    Re: 3300uf 6.3v for xbox
    Seems like this brown cap all the way on the left corner is in parallel with the other two caps I replaced on the lower right side. Is that possible being they are so far away?
    https://prnt.sc/uabe84
    Ryzen 3600x
    16GB Patriot 3600MHz
    MSI B450 Gaming Plus
    MSI Air Boost Vega 56
    Acer 32" 1440P Freesync
    Rosewill Capstone 750W
    Hakko FX-888D Station
    FX-8802 Iron
    MG Chem .8mm 63/37 RA 2.2%
      yes, the caps are often placed close to the chips that consume the most power.
        I mean, I have never seen it before where a cap is in parallel with caps far away on the board. Continuity with the positive lead determines that right?
        Ryzen 3600x
        FX-8802 Iron
          Correct.
          It's actually very common for the voltage rails from the power supply to run all across the board and have parallel caps everywhere where there is high-power consumption, as stj noted. Those brown caps in particular supply that you pointed out appear to supply the VRMs. So it's normal what you see.
            Placing caps close to varying and pulsing loads decreases the trace resistance and inductance between the load and the energy stored in the capacitor. With ICs with very fast high magnitude load transients there often is a network of capacitors of different value and type, some that are very low ESR and ESL but low capacity to respond fast, some that are higher in capacity but also higher ESL to handle what the faster lower capacity caps could not handle. Sun Microsystems was doing this in the mid 1990s.
            PeteS in CA
              Great, thanks for those explanations. My final question is, should I replace that final 3300uf brown cap with a 2200uf to match the other two? Remember I replaced the bottom right one AND populated that empty cap spot with two 2200uf 10v Panasonic FM's. A third Panasonic 2200uf on the left side would complete the original 6600uf total capacitance.
              Ryzen 3600x
              FX-8802 Iron
                no, because your decreasing the cap value.
                if you replace a 3300uf cap, use a 3300uf cap or use a 2000uf polymer.
                if the circuit didnt need 3300uf them M$ wouldnt have paid for one.
                  if you search the forum i'v done a number of posts about this subject and how to upgrade to polymer caps
                  did u notice any difference in performance when upgrading to polymer caps?
                    Caps either do their job or don't. You won't see any differences unless you hook it up to a scope maybe.
                    Ryzen 3600x
                    FX-8802 Iron
                      well it doesnt crash - so the polymers work
                        so high quality caps won't reduce the amount of frame drops while playing a stressful game?
                          framedrop is because the hardware is pushed to the limit.
                            If you don't go the polymer route, I've concluded that these are best cheap option for 1.0-1.4 xbox's.
                            https://www.digikey.com/en/products/...332MHD/2598225
                            And these for 1.6 models since they are closer together and you should go with 10mm wide caps
                            https://www.digikey.com/en/products/...C10X25/6049998
                            Yes 27mm height is acceptable on the right side of the board, just not under the optical drive.
                            Both caps are very low (not quite ultra low) ESR and have adequate ripple current.
                            Ryzen 3600x
                            FX-8802 Iron
                              Hi, I was looking information about the following:
                              I have an xbox 1.0, that has 5x 1500uf caps and I am wondering if can I change those by 3 x 3300uf caps? Would it be safe for the console?
                                yes, but using 5 polymers is better.
                                and the 3300uf caps are tall - so dont put one in the way of the heatsink clip
                                  Thank you for the quick answer @stj
                                  I don't have many options to buy replacement components, I can only work with things in Amazon, because I live outside US and I want to fix my xbox soon.
                                  Maybe I can order the polymer capacitors for the future, so I can replace them some months in the forward, should I use the same specs 1500uf 6.3v and 3300uf 6.3v (I have 1.0 - 1.6 xboxes)?
                                    find my thread about fitting polymers - it has lots of links to aliexpress.
