Hi, some prestory: I was repairing an amplifier - a "Phil Jones Bass". It had some bad capacitors an a faulty power switch. Easy job. However upon putting it back together I screwed up. The connector from the 15V-0V-15V from the transformer is identical to the audio ouput from the preamp board to the poweramp board. I ended up putting +-15VAC into the preamp outputs frying some traces on the circuit board along with the power transformer The transformer is shorted. It blows the fuse immediately even with no load on the secondary.
Now that's a challenge - luckily the preamp board is mostly standard components I already have on the shelf. I'll start by getting the PSU back up and running and run fuses on the seconaries until I know the amp is stable and working.
Looking in the parts bin I don't have a suitable replacement for the transformer. Is it OK to replace the broken transformer with one 50-0-50 and one 15-0-15? Should I connect the center taps together? This would be much easier and cheaper than sourcing a transformer that has the exact windings that the amplifier calls for.
