is this good or do i need more watage?
25w 120v soldering iron?
Re: 25w 120v soldering iron?
I talked to a guy at the Source today he recommended a 15 w or a 20 w.My Computer.
AMD APU A4-3300 2.5ghz 1mb cache
Motherboard GigaByte GA-A75M-S2V
Kingston HyperX Blue DDR3 8GB (2x4GB)
SB Audigy 2 ZS [B800] Sound Card
500GB WD Caviar® Blue™
1 Terabyte WD Caviar® Black™
2 Terabyte WD Caviar® Black™
Canadian tire didnt have anything better besides a 35 but it had a hand gripe whitch would impede proper use and a 80 wat that was too much.My Computer.
I might take it back and get a 30w or a 40 from the sourceMy Computer.
i donlt like the tip design. dont shop at a tire place. get one like mine:
http://www.assemblyoutfitters.com/images/XY-258.jpg - id embed it but it is high resolution. see the knurled part at the base of the shaft? thats how good irons with replaceable tips are. the kind you have has a tip that will not last and can kill boards when it wears out (killed a nice server board that way). screw at tip= bad quality tip that is not made as a replaceable part (so you have to buy a fresh iron) and poor heat transfer. trust me, the reason my 30w does the job is the tip style. my other 30w had your tip and died quick, has crappy heat transfer, and had no replaceable tips avaiable.
i use xytronic because the local electronics shop carried that and since i know the owner, i shop there. id also reccomed hakko because they make great quality at lower prices. weller make great stuff but they charge out the a** for tips. shop online if no quality is avaiable.
remeber that wattage does not account for heat transfer/ honesty of manufacturer. id return that and look online or shop eleswhere where elecronics is the specialty, not tires.sigpic
(Insert witty quote here)
I got that at the Source not canadian tire.
and the tip comes out its just a realy big one lol.My Computer.
Originally posted by PhaihnI talked to a guy at the Source today he recommended a 15 w or a 20 w.
If you look at the pic you attached the 25W - 120V reaches only 205ºC.
To solder and de-solder correctly you need 250~350ºC.
The temperature is important to melt solder, power is important when you have a big area to heat.
So a 25W can be enough to desolder a SMT resistor but will be useless to desolder a cap from a MOBO VRM, where large tracks dissipate the heat very quickly.
Another important thing is the tip, they must be suitable for the area you are going to solder because a thin tip can't solder well even if mounted on a 60W solder.
I use Weller WS50, they have the temperature controller and the maximum power is 55W. When I have to solder small components I set the temperature at 300ºC, but when I have to solder component on large tracks I set the temperature between 350 and 400ºC.
About the 60W you got I think it has enough power but it looks not very comfortable for working on electronics board and probably there are not different tip available but with some practice you will be able to do a good job with it.
Ciao
Gianni"In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
H. J. Brown
Ehh, its a pointed tip. You really wanted to get a flat tip. You can make it a flat tip if you have a grinder or something, or you can get a new tip.
The wires are 22 gauge, good for low current things like fans or small projects, but for smps work you need at least 18 gauge. Solder suckers are always good, and rosin core solder is good. 60/40 is best.
the wire i got for HD motor i wanted to play with ..
i am going to see if there are replacment tips for that iron.My Computer.
Did you mean the iron or the solder sucker?My Computer.
Originally posted by 370forlifeEhh, its a pointed tip. You really wanted to get a flat tip. You can make it a flat tip if you have a grinder or something, or you can get a new tip.
On a related note I just got my FIRST soldering station a Hakko FX-951 it kicks ass . Goes circles around my corded unregulated Hakko Dash. I can even hot swap tips they plug in like cartridges heats up to 350 C in 10 secs.
http://hakkousa.com/detail.asp?CID=49&PID=4482&Page=1
Got it for $211 at tequipment.net. Saved $39 bucks off Hakko's direct price.
As for a standard tip I prefer the conical tips for through hole soldering that's just me though.
If you want a starter station based iron go with the Hakko 936.
http://hakkousa.com/detail.asp?CID=4...ID=1250&Page=1
Can be found on fleabay for around 80 bucks shipped. Beware the clones they may look identicial but they use cheap wire wound heating elements while Hakko uses printed heating elements (and no you CAN'T swap the good elements into the cheaper units). I can't remember the other cut corners at the moment.Last edited by Krankshaft; 08-27-2009, 01:02 PM.Elements of the past and the future combining to make something not quite as good as either.
Originally posted by KrankshaftYou CAN'T grind the tip down you'll lose the plating.
Got it for $211 at tequipment.net. Saved $39 bucks off Hakkos direct price.
Can be found on fleabay for around 80 bucks shipped. Beware the clones they may look identicial but they use cheap wire wound heating elements while Hakko uses printed heating elements (and no you CAN'T swap the good elements into the cheaper units).My Computer.
