samsung ps42c450b1w clicking
    Re: samsung ps42c450b1w clicking
    On this tcon I have checked this fuse and have nothing showing
    Would this be the problem
      nothing showing? are you trying to test it on ohms? or with tv on and voltage each side of the fuse?
        Make sure not to confuse a single "1" on meter with 0.0 ohms.
          Definitely not the tcon board just checked with a working one
          Any other ideas please ?
            Is light on t-con lit up? Flashing?
              Hi yes the light comes on when cycling about 6 times.
              Then goes out
              If I unhook tcon from psu the tv starts up but no picture.
              Or if I unhook y main. It starts up
              I'm getting so frustrated with this tv
              Any help would be appreciated
                So it STOPS clicking with Y-main out?
                  Yes y main out no clicking
                  Y main is good and x and main swapped out
                    And yes sorry tcon light is flashing
                      How are you certain the Y-main is good?
                        Y main was replaced
                          Means f*** all... you could have got a bad board and that has happened to me MANY times. Sellers just don't test their boards.
                            What's the best way to test the y main
                            I know I could have got a bad one
                              Check ohms between Vs and GND, and check all transistors/diodes (mounted on heatsinks.)
                                Have the same model and same problem, TV turns on with Y main disconnected. Did you find problem on y main?
                                  I am having the same problem, if I disconnect the y board the tv chimes but don't get no picture, i have changed power board, t con board and y board, the only possible other thighs it could be is the y buffer board, how can I test this to see if that is the problem, any help and ideas welcome thanx
                                    Here's Tom's Samsung buffer test: http://youtu.be/51SZsfH60EY
                                    This may also be helpful: http://youtu.be/JjrwTZC5nVg
                                    LG Plasma Mal-Discharge Correction Service
                                      I've got a buffer board on order will let u know if it sorts out my problem
                                        have u tested the xsus also im having the same problem as you even though my buffer tested fine ?
                                          I've fitted new y buffer board and still no luck, I have come to the conclusion that it must be that z board, I have disconnected both cables from the y board and the tv gets the chimes but still no pic does that point to the z board?
