help with new psu
    help with new psu
    my psu fan just died on my old psu witch was an ocz modstream pro 500w and im going to change it with a tx650(https://www.newegg.com/Product/Produ...82E16817139005) thats i have had since jan 2014 that never been used just set on a shelf.what happen was my old tx650 died and i rmaed it and i bought the ocz while i waited and never switch them.the only thing that stoping me from using the new tx650 is its been sitting for about 4 years and i can see inside it and it has capxon caps by the wires and i read there really bad.im i just being paranoid or should i look into a different psu
    Re: help with new psu
    Recap it first before you use it
    I do this myself most of the time if the switching power supply does not have well known brand type caps in it I recap it
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
      whats a good brand cap to replace it with?also will the big one need to be replaced to
        You don't need to replace the primary capacitor(s), the primary caps are the 200v/400v rated caps.
        For the secondary capacitors, some brand like Chemi-Con, Rubycon, Panasonic, or Nichicon should work as long as you get the right caps for the job.
        One thing that would be nice to know is what model of capacitors these are, as Capxon makes many different capacitors with different specs (just like the other brands i mentioned). On the backs of the capacitors, you should be able to see two letters next to the temperature rating, the two letters should be the model of the capacitor.
        I'm not a expert, I'm just doing my best.
          the ones i see have kf on them
            https://cdn.badcaps-static.com/pdfs/...0940ffe3f8.pdf
              so do all you guys think they should be replaced
                I think you should replace all of them except the main filtering caps
                Most of time I use KY , KZE, LXY if I can find the right size then FR , FC or its equivalent ESR Value
                I have had very good results using these series before I only had a couple of switching power supply complaint about the ones that I have used in them
                https://www.digikey.com/products/en/...ock=on&pv69=80
                9 PC LCD Monitor
                1 Dell Mother Board
                  First check if the power supply works and also if it has active warranty. If it doesn't work and still has warranty, you might be able to exchange it instead. And if does work, at least you will know, so that if you do something wrong with the cap job, it might give you a better idea of where things went wrong.
