This cooler master G750M came shorted on primary side.
Replaced fuse, bridge rectifier, safety diodes and single mosfet.
After that PSU was powering every one in ten times when i pressed switch, but had high PG on tester, over 999.
Replaced controller ST9S429-PG14. After replacement it powers on when you connect cable for the first time, but high PG remains. It wont power on until you disconnect 220V, let it drain, then connect again - same thing - powers on first time, high PG, wont power on subsequent switch triggering.
Checked surrounding smd components around ST9S429-PG14, all seem fine with DMM.
Any advice where to look what might be?
