Sorry no pics as of right now i just wanted other peoples opinion
Tv does the slow 2 blink 5 fast blink code i have read all threads on similar models i have pulled ribbon from t-con same code it is led edge lit tried disconnect led wires same error code no mater what i do i get same code
I have learned to be more selective as to what tvs i will attempt to repair
because it is a waste of time even if i get the error cleared i have no idea if the back part of the panel is cracked front looks fine but looks can be deceiving
the back side could be cracked and will not know until i get it to light up and then find it was all in vain Question does anyone know positively what i can do with the 2-5 error code because i am not going to waste my time on some that is not worth the aggravation. I am dieing from emphysema and did enjoy electronics as an outlet and i have a lot of experience with these tvs and that is why i will probably say the hell with this tv unless someone has an easy way to tell if it is worth my time. Yes i would like to see it working but at the same time i have learned when it is time to give up i have not taken voltage readings because typically this error is not the power supply budm and ttom have a lot of experience so question 2 all should i just say the hell with the tv and bring it back to the recycling place i got it from
