Soundcraft MFX compatible 60mm faders
    Hi All,
    I'm cleaning up a Soundcraft MFX 8-2 channel desk and could really do with replacing all the faders which are labled:
    10KΩ A 833B (mono channels)
    10KΩ A 833B (Stereo/EFX/Output channels)
    Is there a reasonably priced compatible fader out there?
    I also have an issue with one mono channel which has the signal present LED permantly lit. With a signal going through the channel it has no effect on the LED. The rest of the channel works correctly.
    I've been searching for a service manual for this desk and am drawing a blank so I'm using a SC EFX technical manual as a guide. Is there a significant difference internally between the EFX and MFX ranges?
    Many thanks
