toshiba a200 shuts down randomly and can not resolve this problem, Can you help please?
Toshiba A200 random shutdown
Re: Toshiba A200 random shutdown
You need to give more info. Is it after running for a while or right when you turn it on? If you're going to upload pics you should use the attachments option that way they are easier to view. What I always do if it's shutting down after it's been running a while is check for a wall of dust on the heatsink, it causes lots of laptops to overheat and shutdown....I've seen it so bad that a Celeron laptop idled at 77C and put a little load on it and it hit 100C in no time! Toshiba doesn't seem to have very well designed thermal solutions either, especially if they have an AMD processor, thankfully yours doesn't.
Also, does the fan rev before it shuts off?I love putting bad caps and flat batteries in fire and watching them explode!!
I recently looked at a laptop (Toshiba Satellite L500) that was randomly shutting down at first then always shutting down before completing startup.
As a previous respondent said, a dirty fan was the culprit.
The fan had a thick piece of gathered dust that had knitted together (like the stuff you remove from the filter in your tumble dryer). I assume it had been jamming the fan and causing the system to shut down to prevent overheating.
Either way, clearing the fan, cleared the problem.
I got the same issue in A205. It happened twice before to me. It just shut down during work but only when was working on battery. I think my issue is the weak battery (it just shot down when was 43% of energy left) but those are my thoughts , or some bad capacitor (it was dual capacitor replaced near CPU two years ago).
Did not find any problems on mobo , got cooling system clear and neat , fresh thermal compound.Laptops and computers repair.
Years ago I had an A200 model that would randomly restart or restart when the main board was physically stressed.
I found pin 1 (EN) on the VCORE regulator IC, ADP3208, going open circuit. I thought that this would have to be a one off occurrence.
Lately I met another A200 with exactly the same fault.
To confirm, I heated the IC while doing a DMM diode test on the lower input protection diode on pin 1. I got a fluctuating reading.
After all of these years, I'm still using some of my Satellite A200 laptops.
Mainly the models that use the Intel 965 chipset.
I have just repaired the 2nd one that was randomly shutting off.
I fixed both by replacing a temperature sensing IC near the CPU.
The IC is marked "G784".
Originally posted by ktmmotocross View Postoffcourse it is NEC Tokin capacitor problem. u must replace it with 4x330 capacitors.
I'm totally certain that the temperature sensor ICs were the cause of this recent shut off symptom, not restarting.Last edited by rievax_60; 04-24-2021, 04:45 AM.
