Re: Benq G2255 doesn't power on - amber power light when plugged in
Hi Will,
Since you said "C831, C833 & C832 form a capacitive voltage divider for the chip to monitor voltage on cn801. The values are critical", is set out to try and measure C835 & 836 / C833 & C832 with my Fluke multimeter, but wasn't getting any reading.
So I took my transistor tester with which has a capacitance function (and an ESR in circuit function, but I didn't use this one, I used the capacitance function only), and with my probes checked them. Here is what I got and not sure if this little machine is accurate, but it was constant:
C835 / C836 : 42.8 uf ESR .15K Vloss 14%
C833 / C832 : 143.2 uf ESR .15K Vloss 12%
I think these are in pairs, because I would get the same reading say from C835 and C836, the same for the other 2.
Not sure if this can have a meaning of some sort?
Hi Will,
