Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 09-22-2023, 07:57 AM   #21
dustman1747
City & State: PA
My Country: USA
I'm a: Knowledge Seeker
Default Re: Sony XBR-65X900H vertical lines
I did watch the video, mine is an H series though and appears different. My TV only has a white and red light that I have seen. I used a 2gb drive and the white light pulsed for a few minutes then the light turned off. I presume it took the update because there was audio again but no picture after the pulsing stopped. I tried renaming the files to force another update but no luck. The firmware for this version comes in a ZIP not a PKG but I tried it anyways.
I did run across a technical bulletin for t-con and/or main board replacement procedure. It requires a WB/MURA/CUC data transfer between the t-con and main but this requires the screen to at least turn on so the service menu can be used.
As a last ditch I did order another t-con and new lvds cable to rule them out.
Not sure where to go from here.
dustman1747 is offline   Reply With Quote
Old 09-22-2023, 10:26 AM   #22
Davi.p
Davi.p's Avatar
City & State: Milan
My Country: Italy
I'm a: Hobbyist Tech
Zip files are not suitable for tv updates, them must be uncompressed in the usb key root
Davi.p is offline   Reply With Quote
Old 09-22-2023, 11:23 AM   #23
dustman1747
City & State: PA
My Country: USA
Quote:
According to Sony's support page for this model it looks like it call for using the zip
Quote:
Download the Updater:
Before you install the update, you'll need to download the update files from the Internet and save them to a USB flash drive.
Click the Download button at the top of this page, then read and accept the terms and conditions.
Once you have accepted the terms and conditions, click the Download button at the bottom of the page to download the update files to your computer.
Verify the downloaded file names and size (see the File Info section).
Extract the downloaded files to a location on your computer you can easily find.
Make sure that a sony_tvotafull_202x_zzzzzzzzzz_yyy_auth folder is created and that it contains the following files:
sony_dtvxxxxxxxxxxxx_xxxxxxxx_zzzzzzzzzzzzzz.zip
sony_dtvxxxxxxxxxxxx_xxxxxxxx_zzzzzzzzzzzzzz_xxxx. dep
Connect the USB flash drive to your computer.
Go to the location where the extracted files are saved and copy (or drag and drop) the two files from the sony_tvotafull_202x_zzzzzzzzzz_yyy_auth folder into the root directory of the USB flash drive.
Note: The root directory is the first or top-most directory of the device, which contains all the other folders.
Remove the USB flash drive from your computer and continue to the next section
Old 09-22-2023, 11:37 AM   #24
Diah
City & State: SA
My Country: Germany
I'm a: Professional Tech
you are wrong... this TV android... update always with zip....
Quote:
plug the TV out from wall socket wait view minuts.... press the joystic and pull it down.. keep it in this position... and plug it in wall.... the fron LED indicatore will change to green color at this relase the press
Diah is offline   Reply With Quote
Old 09-24-2023, 03:46 AM   #25
zomi
I always extract the file and put the .pkg on the root of the usb stick.
zomi is online now   Reply With Quote
Old 09-24-2023, 07:18 AM   #26
Diah
City & State: SA
My Country: Germany
Quote:
yes you are correct,, if the .zip after extracting there .pkg then should use .pkg
Old 09-26-2023, 08:42 PM   #27
dustman1747
City & State: PA
My Country: USA
Tested a second t-con and a new set of lvds cables, still can't get an image. Probably going to call this a one a loss.
Old 09-27-2023, 12:07 AM   #28
Davi.p
Davi.p's Avatar
City & State: Milan
My Country: Italy
have you read the second page posts? how about software attempts?
Old 09-27-2023, 02:47 PM   #29
zomi
power the tv with the tcon disconnected
should give the error with the green/ amber light
then you will have to update/ pair it
then add usb with update file and see what happens
worth a shot
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2023
Powered by vBulletin ®
Copyright ©2000 - 2023, Jelsoft Enterprises Ltd.
