Plasma LG 50PT353 picture grainy
    Please for some help.
    My plasma suddenly have grainy picture. Which board should I look first?
    Re: Plasma LG 50PT353 picture grainy
    Are all your voltages Vs, Va, Vy, Vsc, Z-bias on the label correct? This looks like a bad Z-sus Bd.
      Andrew F. Ali, yes the voltages are correct. I changed with another working PSU, and measured with Fluke, all OK. I will buy ZSUS and we will see.
      Thanx for your help.
        Before you buy Z-sustain how did you check Vzbias voltage??
          Tom66, please look at the attachments. Is this correct VBias measurements?
          What are you suggesting me? Thanx for your help.
            Yes that is the Vzb 9Z-bias) test point.
              Should I adjust a little Vy,Vsc and Vzb?
                Were they within about 3 volts of the values on the sticker? If so, there is no need to adjust.
                  Tom66, thanx for your answer. When the ZSUS board 'll come, I will report here.
                    try to resolder big coil on Z-sus board....
                      Today I changed Z-sus, and the result is the same.
                      Any other suggestion?
                        did you find out what the promblem is?
                          Nah, i think he sent that one to the landfill.
