Bush DLED40127FHDCNTD - Software dump
    Have one of these Vestal built dumps in the workshop at the momemt with a faulty mainboard. I also have a working one as well that is currently up for sale - both sets have the same part numbers on the main board and is there a way of extracting the firmware off the working set onto USB? Then to install onto the corrupted one?
    Re: Bush DLED40127FHDCNTD - Software dump
    You can look into editing the boot configuration file on an update USB.
    These vestel sets use u-boot which is open source software. It is what loads the flash memory correctly.
    It is possible to edit the u-boot txt file to make it copy the flash to a USB drive, instead of load the flash image. However, do be aware, that when messing with things like this, it is possible to brick your working set, if you get a command wrong.
