Hello
I have had this TV for a long time. The first panel it had started to show vertical lines on the left side of the screen related to the ribbon tabs, althoht the panel started failing after.
We replaced the panel for a used one and after 2 years it's starting to exhibit the same behavior. It's only a thin red line that shows on the left side of the screen, same location
Right now it's only a thin line that disappears after a few seconds. But eventually the line won't disappear and it will bring new friends to the party.
I assume the problem are the ribbon tabs, as usual that are getting damaged or unglued.
I found a guy on another forum who is using thermal gap pads. The problem is that they have to be shipped from the US and I am not there.
Do you have any other solution to solve this issue or how to get these thermal pads?
This is what i saw: https://uselessforums.com/threads/ar...-issues.13670/
Thank you.
Thank you.
