help indentifying component please
    hi to all
    i hope someone can help me with this component found on my mouth hydrocleaner. it's china style gadget and coulnd't find what this IC is..
    Device is working with a lithium battery 3.7v and can be charged with usb 5v.
    any hint is really appreciated..
    Re: help indentifying component please
    It might be a dual mosfet like a Alpha & Omega AO6402A
      It might be a single mosfet, are pins 1,2,5,6 connected together?
      Is that number 4T6V ? is there a dash above the V ?
        hi, thanks for your answer
        YES 1,2,5,6 are connected together on the pcb.
        YES i read 4T6V but coulnd'nt find nothing with this code.
        NO, i can't see any dash above the V.. but on the side there is what seems "1B"
          AFAIK AO6402A single N-channel
          Seem AO6424A:
            That should be the one, AO6424A, What seems to be wrong with it?
              I guess my chosen word went wrong. "seem".
              Come here on Great Forum not only want to learn electronics, but also I've want to learn to be good on conversation/writing on post. Sometimes i didn't really understand if without help g**gle translate, sometime the translator make more worst as well.
                mosfet does not switch on when 3v are applied to gate. so i have no ground to my motor.
                btw thanks to all for the answers.
                i wonder how you could identify this component, since i tried on smd lookup marking codes table and found nothing.
                thanks again
                sometimes our english is not the best i know, (i am not english native too.. ) but i hope we can understand each other
                  Mostly 99% work on laptop repair, from there i knowing alpha omega's mosfet. Also have several time see mark with "dash" and number/letter with orientation anticlockwise 90 degree on the end body package. BUT totally newbie at all, that's way reading many threads for learn.
                    thanks again
                    Just wondering Why the chinnesse stuff put marking on PCB M2 and using mosfet?
