Quick 70gw+
    Quick 70gw+
    I have a QUICK 70GW+ SMD rework station. it hot air gun not working, blower on but heat gun not working, display see heat 35 not up to going heat. any one help me.
    Re: Quick 70gw+
    check continuity on heating element
      Re: Quick 70gw+
      Also check either a for a relay if it has one or triac or mosfet or something else that would control the heating element if it has a optic sensor check that the input side is getting a signal to turn on if you have a signal on the input then check output for power
      Check wiring going to the element also check and see if it has a thermal fuse or not
      9 PC LCD Monitor
      6 LCD Flat Screen TV
      1 Dell Mother Board
      15 Computer Power Supply
      All of these had CAPs POOF
