Hello to all
I have this resistor from the PS4 SLIM 17-160p1a power supply that seems to be out of order. Does not give any Ohm or Kohm value ect.., neither diode, nor in continuity it must be cut.
I am looking for the value of this resistor ... What is strange the 3rd ring is silver.
Should I consider it as this?
Value 16.8 Ohm normally according to color code (See photo) or 0.16 Ohm
1st ring = Brown = 1
2nd ring Blue = 6
3rd ring Gray = 8
4th ring OR Multiplier = x0.1 Ohm
5th ring Red = +/- 2 %.
Tolerance of + or - 0.336 ohms
If someone has a PS4 Slim power supply and has the right value =D because according to the series of power supplies the manufacturer has chosen the same value for all
2nd ring Blue = 6
3rd ring Gray = 8
