Thread Tools | Display Modes |
#1 |
Oldbie
City & State: Melbourne, Victoria
My Country: Australia
Line Voltage: 240v
I'm a: Hobbyist Tech
![]() Had this a while, and recently decided to use for a build
Was working fine, until froze up in the final stages of a Win7 update ![]() Since then, most obvious problem is every time started after power off, comes up with message: "Default BIOS settings have been loaded due to BIOS update or checksum issue" Please don't suggest battery - first thing to be replaced Then I convinced myself its KZGs must be the culprit, so replaced them with recycled MBZ and, for sharp-eyed, newer KZG in VRM input - all tested OK on ESR meter Made no difference I've tried different processors, different memory, different battery - nada Any insight or suggestions? - my gut feeling is flakey CMOS memory, but isn't that built into Southbridge now?
__________________
better to keep quiet and be thought a fool, than to open your mouth and remove all doubt Last edited by pfrcom; 02-04-2019 at 10:08 PM.. |
#2 |
City & State: OK
My Country: USA
I'm a: Professional Tech
![]() Did you update the BIOS and if so can you go back to any previous version?
#3 |
City & State: OK
My Country: USA
![]() Do you have an HP BIOS on it or an ASUS BIOS. (checksum error)?
Googling on it shows some people say board not compatible with 7. Can you load Vista or XP on it to see if the same problem occurs? More info please. |
#4 |
Oldbie
Line Voltage: 240v
#5 | |
Oldbie
Line Voltage: 240v
![]() Quote:
Tried loading XP recently, for another reason Left it alone for the tedious early stage, came back to a blue (only) screen and frozen Ctrl-Alt-Del didn't work, nor did shorting reset pins on Front Panel header - had to power off, thus back to BIOS settings Board was working perfectly with Win7 Had loaded it up, installed drivers, activated, installed KB3020369, and then it froze during install of KB3125574 |
#6 |
Oldbie
Line Voltage: 240v
![]() Update:
Reverted BIOS to 5.17, then clean installed XP SP3 After power off, same problem |
#7 |
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
![]() I doubt this is the issue, but... I notice in the uploaded pictures above that one of the memory modules may not be completely in the RAM slot, judging by the slightly unlocked RAM lock lever.
Aside from that, I wonder if this motherboard's issues have something related to the common "Chassis Intruded" problem seen on other ASUS motherboards. What's a bit unsettling is that I also have an HP PC with an IPIBL-LB mobo that's been a bit finicky. Namely, when I got the board, at first it wouldn't always boot, then sometimes it would interpret the power button as a reset button, and it also manage to freeze on me a few times. But after using it for a while, the issue went away? ![]() ![]() Anyways, I know this isn't quite helpful. That said, going with your gut feeling about the flakey CMOS RAM also sounds plausible to me. As for whether CMOS RAM is in SB or not... I'm not sure, but you can check the small ICs on the board. I think many boards of that era still used separate chips for storing CMOS. Last edited by momaka; 02-05-2019 at 11:39 PM.. |
#8 |
City & State: Forbidden
My Country: Indonesia
Line Voltage: 220VAC 50Hz
I'm a: Knowledge Seeker
![]() Also I'm notice " a jumper".
Is it on correct set position? |
#9 |
Oldbie
Line Voltage: 240v
![]() That jumper is related to SPI BIOS recovery
It is correct, and required, according to SPI Header section of https://support.hp.com/au-en/document/c01324212 Board won't power on if jumper is removed |
#10 |
Oldbie
Line Voltage: 240v
![]() ICH9 has "256-byte battery-backed CMOS RAM" according to attached
Hmmm, this P.O.S. is getting dangerously closing to joining its colleague the GA-Z77H-D3H - https://www.badcaps.net/forum/showthread.php?t=74364 |
#11 | ||
My Country: U.S.A.
![]() Quote:
I'd still check for any external CMOS chips, though. Maybe ASUS didn't use the one in the NB? (On second thoughts, I need to pull my IPIBL-LB from storage and remove its CMOS battery, as I will be moving it into deeper storage soon and don't want its battery to go bad in there. Could concurrently check with you if there is such a chip then.) Quote:
BTW, did you look into the possibly partially seated RAM, as I mentioned in my previous post? I know it's something you wouldn't miss... but it would be almost nice if the problem was a simple issue like that. |
#12 |
Oldbie
Line Voltage: 240v
#13 | |
City & State: OK
My Country: USA
![]() Quote:
#14 |
City & State: OK
My Country: USA
![]() Another thing to check.
You say HP BIOS update, might be a hidden BIOS menu. Worth looking into. F2, F10, F11? |
#15 |
City & State: OK
My Country: USA
![]() https://retrohelix.com/2012/09/how-t...-hp-computers/
Found this, might help getting into the advanced BIOS settings menu. If your CPU fan is turning below a certain RPM or stalls at some point in the boot process the BIOS CPU protection sensors maybe shutting you down. In that case you need to disable CPU FAN MONITOR DETECTION. |
#16 |
Oldbie
Line Voltage: 240v
#17 | |
Oldbie
Line Voltage: 240v
![]() Quote:
Have tried Ctrl-F10/F11/Ctrl-F11 a few times, but succeeded only once in getting the Advanced menu With wisdom of hindsight, I should have disabled fans detection then |
#18 |
Oldbie
Line Voltage: 240v
![]() Most recent attempt was replacing the last remaining KZG (capacitor racism), a 470uf 16v, with a new KY
At the same time removed, cleaned and replaced the battery holder, underneath which looked a bit grotty Didn't make any difference ![]() |
#19 |
Oldbie
Line Voltage: 240v
![]() FWIW, other weird behaviour is, if I short Reset pins on Front Panel header, more often than not there's a delay, then it powers off
At that point just shorting the Pwr pins won't start it - I have to switch power off & on before it will start again So I need to remember to use Ctrl-Alt-Del for reset Something fundamental seems to have gone wrong with its electronics - reckon I'm ![]() |
#20 | |
City & State: OK
My Country: USA
![]() Quote:
Thread Tools | |
Display Modes | |
