Panasonic FS series low-ESR lytic caps
    Panny FS Datasheet
    16V 2200uF in 10mm ⌀ diameter.
    Cheaper than FM and FR.
    What do you think about this series, gentlemen?
    Re: Panasonic FS series low-ESR lytic caps
    cheaper??
    i cant find any stocks yet!!
    they are smaller, kind of a replacement for FK or for use when FR is too big
      RS has some.
        In the US, DigiKey has them, Mouser has no listing for them yet.
        Stupidity should be a crime, especially for drivers. I have NO patience for them.
          Higher capacity ones (I think it was around 1500uF) are quite good and have very low ESR, smaller ones are pretty shit, FM should be prefered. Even over FR.
          I've looked up Datasheets of AFAIR 680uF/6,3V ones. And the FM was equal to Nippon KZG or even better.
          The other Panasonic (FR and FS) aren't even close...
          Though in 2200uF/16V the FS are better and smaller, if I remember correctly...
            ... i cant find any stocks yet!! ...
            Newark Element 14 USA
            Originally posted by Stefan Payne View Post
            Higher capacity ones (I think it was around 1500uF) are quite good and have very low ESR ...
            Yup, some of the larger ones look interesting.
            10V 10mm ⌀ 2700uF ESR= 0.018
            16V 10mm ⌀ 2200uF ESR= 0.018
            And a monster 5100uF 16V ESR= 0.012 in 12.5mm ⌀ x35mm (same can size and ESR as FM 16V 3300uF)
              I think that my Chemi-Cons KYB 2200/16 are cheaper, Samxons RS 3300/16 have higher capacitance and KZNs 3300/16 are better in every possible way.
              So once again, why should I even think about overpriced Panasonics with their crazy ill MOQs? Like srsly, almost a buck for 2200/16, you serious?
                eye watering isnt it!
                re-caps can get pretty costly now!
