Here's are some pics of this problem. I haven't opened it but wanted to see if anyone was successful in fixing a problem like this.
Sony KDL-46VL130 Distorted / Double image
Re: Sony KDL-46VL130 Distorted / Double image
For me too side driver tabs, i have a test for you, lets we se if i find one christian in the universe that agree to do this test...
open the tv, tell me if the screen is a Samsung first, locate on the tcon the testpoint called CPV1,2 or CKV1,2, the tags can vary, then with the multimeter continuity locate to which pins of the connectors > panel them are connected, them are repeated in parallel on the right and the left connectors, now with adhesive tape cut 2 hair style strips to mask on the flat cables the pins found , first try with CPV1, then if the defect don't disappear try CPV2, one at a time.Last edited by Davi.p; 11-10-2017, 06:06 AM.
Thanks for the advice. I have the tv open and want to try this "cut-off" method. I do have a Samsung (pn#LTY460HB01) panel. I have located CPV1 and CPV2 on the TCON but not sure which is which. When I put my one test lead on the left side of C16 on the TCON (right next CPV1 & CPV2 labels -- see photo) and the other I run across FPC left or right, I get 18 points that have continuity. When I put my test lead on the right side of C16 I don't get any points of continuity on the FPC contacts. I'm missing something.
I have repaired numerous set with similar problems and have them in my personal residence and they are still working like a champ after 3+ years. If you have bad connections where the ribbons go into the panel the set can be saved. If the bad connection is in the drivers build into the ribbon cable it's a wrap.
Originally posted by Hy4woj View PostI have repaired numerous set with similar problems and have them in my personal residence and they are still working like a champ after 3+ years. If you have bad connections where the ribbons go into the panel the set can be saved. If the bad connection is in the drivers build into the ribbon cable it's a wrap.
OK first of all i've written incomplete instructions, first thing to do is to run the tv with one flat cable disconnected at turn, you will probably become to the setup where you have half good image half black, so you must mask the traces from the bad side. Second: on your picture C16 does not matter's at all, CPV1,2, STV and VST2 are markings for the 4 testpoints to it's right hand, them are also surely connected in parallel to the left hand side (in picture) of the left connector, where you don't see testpoints. Now with an only piece of adhesive tape try to mask all CPV1,CPV2, STV and VST2 and maybe also VST1 of the faulty side flat cable. Don't cut the lines 'cause this mod is probably not so long lasting and when maybe the screen will finally die you could sell tcon board. Bye.Last edited by Davi.p; 11-18-2017, 03:35 AM.
Sorry the image is bad on both sides .... I was looking forward to doing this repair and really appreciate all of the input. Just so I understand the fix clearly, do I mask the connections on the tcon or cable? Or does it matter?
And could it be the TCON after all?Last edited by fcisolutions; 11-20-2017, 12:47 PM.
T-CON cannot cause the horizon bars on the screen.Never stop learning
Surely is bad panel. I think i can distinguish 2 common problems togheter in this set, horizontal streaks+double image and dark in the central part, the second defect is usually caused by a damaged horizontal tab bond, the more at east or the more at west, by pressign it the problem disappear, now when you done the "one flat at a time" test, the defects was the same on both sides? Maybe is the first time i see when you have one horiz. tab bond and one vert. tab bond failed.Last edited by Davi.p; 11-21-2017, 09:55 AM.
