#1 |
City & State: Kingman,Az
My Country: United States
![]() Everything looks good no fuses blown maybe the lower bottom cap might be bulged a little but nothing I can see, I order a cap kit today , Am I on the right track?
#2 |
City & State: Federal Way,WA
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
![]() It could be the angle of the pic, but it looks like you have quite a few blown caps on the left side of pic 2. I count 8 - possibly 9. I can't clearly see the cap closer to the top of the pic on the left side (E3). That would be the possible 9th blown cap.
I've attached a pic of two caps, just in case you're not sure. The cap on the left with the domed top is bad, while the cap on the right is visibly fine.
LG Plasma Mal-Discharge Correction Service Last edited by capkid; 04-14-2015 at 09:41 PM.. |
#3 |
City & State: S.F. Bay area
Line Voltage: 120V 60Hz
![]() Looks like at least 9 bad caps with domed tops to me too.
Never stop learning Basic LCD TV and Monitor troubleshooting guides. http://www.badcaps.net/forum/showthr...956#post305956 Voltage Regulator (LDO) testing: http://www.badcaps.net/forum/showthr...999#post300999 Inverter testing using old CFL: http://www.badcaps.net/forum/showthr...er+testing+cfl Tear down pictures : Hit the ">" Show Albums and stories" on the left side http://s807.photobucket.com/user/budm/library/ TV Factory reset codes listing: http://www.badcaps.net/forum/showthread.php?t=24809 |
#4 |
![]() Thanks guys appreciate it
#5 |
City & State: Los Angeles/San Dimas, CA
![]() Don't run to Radio shack.
Get Panasonic FC or FM capacitors from Digikey. Select USPS First class mail for shipping and that way is pretty cheap. Once I have repaired one of these too. I remember, that somebody created a site on how to repair these. |
#6 |
City & State: Latrobe, PA
![]() About bad caps on the Polaroid FLM-3701:
The nine big output caps E8 thru E17 go bad and they will be obviously swollen. E8 - E13 are 680uF 35v and E15 - E17 are 680uF 25V. However, there are three small 22uF 50V caps that also go bad. They look normal. They do not swell. They are E7, E8, and E22. Be sure to check those with an ESR meter. |
#7 |
Never Give Up !
City & State: Telford
My Country: Britain
Line Voltage: 240 VAC 50Hz
I'm a: Student Tech
![]() Them bad caps are just the start ! You probably have the secondary output failure basically on these Kas boards bad caps cause a small Smd diode to fail which causes no standby.
#8 |
City & State: Elizabethton TN
![]() I have the somewhat similar Polaroid flm-373b that I have repaired twice but now , even after replacing all the caps again , it has no standby light . No indicator light at all and fuse(s) look good. Could you elaborate a bit on which diode i should check ? Would it be better at this point to replace the whole board ?
#9 |
City & State: North Springfield, Vermont
Line Voltage: 118-127V 59-63.5 Hz-> actualizo: pérdido de voltaje
![]() I see 8 bulged caps...
ASRock B550 PG Velocita Ryzen 5 "Vermeer" 5600X 16 GB G. Skill Ripjaws V F4-3200C14D-16GVR Sapphire Nitro+ Radeon RX 6600 XT eVGA Supernova G3 750W Samsung 970 Pro 512 GB NVMe SSD "¡Me encanta "Me Encanta o Enlistarlo con Hilary Farr"!" -mí mismo "There's nothing more unattractive than a chick smoking a cigarette" -Topcat "Today's lesson in pissivity comes in the form of a ziplock baggie full of GPU extension brackets & hardware that for the last ~3 years have been on my bench, always in my way, getting moved around constantly....and yesterday I found myself in need of them....and the bastards are now nowhere to be found! Motherfracker!!" -Topcat "did I see a chair fly? I think I did! Time for popcorn!" -ratdude747 |
Thread Tools | |
Display Modes | |
