Re: Acer AL2423W Recapped, backlight works but no display
Yes. These regulators are available in fixed and variable output versions.
The pins are numbered 1, 2, 3 across the bottom. 3 is the input, 2 the output, 1 the adjust. By using a pair of resistors from pin 2 to pin 1, and from pin 1 to ground it is possible to set whatever voltage you want. If you notice the voltages, pin 2 is 1.2 volts higher than pin 1.
PlainBill
Originally posted by retiredcaps
View Post
PlainBill
