Toshiba 32W1333DB no backlights
    I have a Toshiba 321333DB with a Vestel 17IPS11 power board.
    The TV powers up but the backlights do not light.
    If I externally power the LED's I get a picture.
    Any pointers?
    Vestel 17IPS11 Schematic linked below:
    https://www.badcaps.net/forum/attach...1&d=1614948277
    Re: Toshiba 32W1333DB no backlights
    Check your BL_ON voltage level at power up.
      When the set is on it's reading 3.26V
        Do you have the 24V, 12V and 5V supplies? How about VCC pin 16 of U103.
          Measuring at CN100
          Pin 1 = 23.6V
          Pin 5 = 5.3V
          Pin 13 = 11.9V
          U103
          VCC (pin 16) = 5.9V
            Did you mean pin 15 (VIN) = 11.9V
            Does D107 cathode voltage peak sharply and drop when you come out of standby?
              U103
              Pin 15 = 9.3V in standby > 11.9V when on (it seems stable between the 2 states and not jumping around)
                Everything appears to be in order so far.
                Is U103 pin 16 at 6V when out of standby.
                What was the peak voltage at D107 cathode when switched out of standby.
                  U103 pin 16 is 5.9V when out of standby (TV on)
                  D107 Cathode is 22.3V
                    Back tomorrow
                      The led driver chip is not boosting the incoming 22.3V to drive the leds.
                      Check the diode D107, D138 & D110 using your multimeter in diode mode and also the mosfet Q103, transistor Q110 and R187. There are plenty of videos on Youtube showing how to test the components.
                      Check this video out https://www.youtube.com/watch?app=desktop&v=RxwdC7V5Ue0
