Thread Tools | Display Modes |
#1 |
![]() I have an ASUS motherboard with 2 bad capacitors, I have replacements but the joints are very small, my desoldering braid won't remove the solder. What else can I use to desolder the bad capacitors?
#2 |
City & State: Canada
![]() Add some 60/40 solder to the joint first.
__________________
--- begin sig file --- If you are new to this forum, we can help a lot more if you please post clear focused pictures (max resolution 2000x2000 and 2MB) of your boards using the manage attachments button so they are hosted here. Information and picture clarity compositions should look like this post. We respectfully ask that you make some time and effort to read some of the guides available for basic troubleshooting. After you have read through them, then ask clarification questions or report your findings. Please do not post inline and offsite as they slow down the loading of pages. --- end sig file --- |
#3 |
![]() Can I use my 100w Weller or should I use my 45w Radioshack iron with a chisel tip?
#4 | |
![]() I try to wick the pads on these boards, so I know how you feel. 3/4 of the time, it won't completely wick, especially if the pad is near something that absorbs a lot of heat, like a copper coil or a grounding plane.
What you will have to end up doing is trying to coax the cap in while holding the iron to the pad. Be careful not to rip up the pad. If you do, you may as well toss out the board unless the lead has attached to the via (I think you can test this with a multimeter). Quote:
__________________
...Their plight, in fact is even worse, they don't realize that they're cantonists, they think they're free men. What a slavery that is - to confuse slavery for light, and bitter darkness for bright light. -Rabbi Menachem Mendel Schneersohn |
#5 | |
![]() Quote:
Once the cap is loose, heat up a stainless steel sewing needle from the backside and push until it clears the hole. I just switched to this method from a solder sucker and it is way easier. |
#6 |
![]() I'm not able to clear holes with a sewing needle. It just gets stuck in there.
#7 |
![]() Thanks. I'll get some 60/40 to make the joints bigger, then use the wick to remove the rest of the solder and remove the bulging Ltec's.
#8 |
![]() Looking on the Radioshack site, I found a nice desoldering iron. I've decided to buy one of those on Friday, with some 60/40 Rosin Core solder to desolder the old Ltec's and solder in the new Rubycon MBZ's.
#9 |
City & State: Maidstone Kent
![]() A good quality flux will help because it allows the heat to melt the solder.Manufacturers of electronic PCBs seem to make the PTH,s very small so components are a tight fit. If the capacitors are defintely going to be replaced you could always cut them off the board and take the pins out the board.
Barry Wilkins |
#10 |
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Hobbyist Tech
![]() Another thing you can do is pre-heat the board. I have a sub $20 heat gun for this that works great - I just blast the area of the board below the caps for 10-20 seconds or so and then use the soldering iron to heat the pads one by one on each cap and then wiggle the cap out. If you don't have a heat gun, a hair dryer will can also work okay - you'll just need to heat the board for a bit longer.
Flux and/or 60/40 lead solder is also very helpful. In any case, don't be afraid that you'll burn the board with your soldering iron - you very likely won't. Keeping the iron on a joint for 10 seconds or more is usually not fatal. Lastly, make sure the tip of your iron is clean and well tightened. |
#11 |
I see dead caps
City & State: Hiding inside a plated-through hole
My Country: New Zealand
Line Voltage: 230VAC 50Hz
![]() I've struggled with some boards, with a 60 watt digital soldering station and even an 80 watt desoldering gun I borrowed, and after research and a bit of testing I have come to the conclusion that some boards (or some areas on the boards) are really only easy to work on with pre-heating.
#12 |
![]() I haven't tried desoldering or soldering on it yet. I will tomorrow once I get the 45w desoldering iron. I got my Rubycon MBZ's today, I ordered 8, and I got 12! Score! Thanks eBay! And they're not Rulycon fakes either!
#13 |
I see dead caps
![]() Unfortunately just because they don't say Rulycon doesn't mean they're not fake.
eBay is a big haven for fake capacitors. The fact they gave you more than you ordered seems suspicious to me - why would a legit seller with a genuine product give you more than you paid for unless by accident? Who did you buy them off? |
#14 |
![]() I bought them from here http://myworld.ebay.com/ny-electroni...id=p4340.l2559
They all have the same date code, 0524. The bung in all of them look the same, as well as the vent. They don't look fake to me, and I've seen a lot of MBZ's. |
#15 |
![]() Yea, I'm pretty sure their stuff is legit. Did you order only two? Why not re-cap the whole board?
#16 |
![]() It was an 8 piece set. No reason to, none of the other capacitors are bloated. They're OST (I know they're a bad brand, but if you keep them cool, they'll be fine), and UCC KZG (They don't like heat either, but I keep at computer pretty cool, so I won't replace the rest of the capacitors unless they bulge.
#17 | |
![]() Quote:
#18 |
![]() I've ran small FFT's on it in Prime95 for about 2 hours and 30 minutes now, still going strong.
#19 |
![]() Recapped the board tonight, was a pain in the a$$, thought I killed the board, but it's booted up and playing a YouTube video as I type this. I'm never soldering on an ASUS motherboard, ever again. lol.
#20 |
![]() It is not just ASUS. Pretty much all motherboards are multilayer and the copper planes suck up all the heat from the iron tip making it hard to desolder. Having a clean tip, flux, 60/40 solder, and the correct tip helps alot. A chisel tip is good for desoldering. The sharp conical tips don't have a lot of surface area for heat transfer.
Thread Tools | |
Display Modes | |
