Go Back   Badcaps Forums > General Topics > General Computer & Tech Discussion
Old 03-22-2010, 02:53 PM   #61
stj
stj's Avatar
City & State: Europe
Default Re: Cleaning Motherboards - ATTN SMOKERS!!
make sure the isopropanol is not from a medical supplier unless you can read the label first.
you need pure - as in 99%+
most medical IPA is 60% distilled water.
and the reason you remove battery's, socketed chips etc, is so you dont trap dirty water or cleaner under them.
although i wouldnt re-fit a used battery in a mobo anyway.
it's o.k. in a radio or something,
but in a pc you dont want to have to open it again in 6 months just to replace a flat battery.
Old 03-23-2010, 02:36 PM   #62
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
City & State: Phoenix, AZ
Line Voltage: 120V 60Hz
In the US you can easily get 91% at many drug stores.
Walmart usually has it cheaply in the larger 32 oz bottles.
99% would be ideal but 91% works perfectly well.
The more common 70% works too but it's not nearly as effective and you end up using a lot more to get the same job done.
After I use what ever cleaner I flush the PCB with hot water to get the cleaner off, shake it semi-dry, then use Isopropyl [via a spray bottle] to blast the water out from under IC chips and out of the sockets & slots.
The Isopropyl dries fast, takes the water with it when it evaporates, and leaves no residue [unless you didn't get it clean with the cleaner].
Water followed by Isopropyl is the approved method used by the USN for electronics that have been drenched in sea water.
- USN ships [as most I think] use sea water for fire fighting so ships have sea water pipes, valves, flanges all over the place inside and once in a while something breaks.
- I have literally [and personally] cleaned up over 10 million dollars worth of equipment using the method. - It works good!
Mann-Made Global Warming.
- Dr Seuss
PCBONEZ is offline   Reply With Quote
Old 03-27-2010, 02:27 AM   #63
Huckfinn
I have successfully used 409, Windex and various citrus cleaners like De-Solv-It citrus solution. I always rinse with warm or hot water. Using pure alcohol to pull out water is a good idea for getting out water trapped under chips, etc. Follow with blow gun from shop air [ be careful to not damage delicate parts with the air nozzle ] and a finish drying with a good quality hair dryer speeds the process so you can power on and test right away without having to wait a day or two. I have done this hundreds of times to CPU boards, industrial controller boards, TV boards and much more. Of course you have to be careful with PC boards that have IF coils, or lcd displays attached, etc.. and do a very careful workaround or de-solder the parts that can not be wetted and dried out easily. Also some LED display assemblies with plastic components and/or plastic contrast filters do not take kindly to alcohol, as that can fog or damage the plastic.
Huck
Huckfinn is offline   Reply With Quote
Old 04-08-2010, 06:50 PM   #64
AudioCraZ
City & State: Bakersfield, CA
My mom was the worst with her smoking at a computer. I pulled the side panel off her case one day, and where there were small 1/8" holes in the side panel, there were little cone "piles" of soot on the inside of her case... very nasty. Had to tell her she can't smoke next to her computer. She tried to give me the "they should make them smoke proof" excuse, but told her she couldn't afford those parts.... Just nasty.
Never could understand why people smoked, never made any sense to me.
AudioCraZ is offline   Reply With Quote
Old 04-29-2010, 07:38 AM   #65
Kona
Do you think this cleaning method would be OK to use on a ADSL Router? They have no BIOS battery to remove but they manage to keep their time somehow, will that remaining charge cause a problem?
Kona is offline   Reply With Quote
Old 06-10-2010, 10:36 PM   #66
Uranium-235
Muffins
Uranium-235's Avatar
City & State: tehas
My Country: US
Line Voltage: 120VAC 60Hz
one of our old employees took a laptop motherboard that got wine spilled into it, and put it through a dishwasher. worked great after that, but thats the only time that worked for us.
smoking is terrible, but we got this HP that reeeeked of cat piss, it was coated in a sticky film all over the motherboard inside. it looked like they left the cover off while the cat pissed inside it and left it there.
Uranium-235 is offline   Reply With Quote
Old 07-26-2010, 02:39 PM   #67
RJARRRPCGP
City & State: North Springfield, Vermont
Line Voltage: 118-127V 59-63.5 Hz-> actualizar: pérdido de voltaje
I LOL'ed.
Asus P6T6 WS Revolution
Core i7 Extreme "Bloomfield" 965
Asus Strix GeForce GTX 970
Windows 7 SP1
SoundBlaster ZXR
Corsair TX850M PSU
Looks like I have a laptop that kills a desktop PC!
Received on November 4, 2019:
MSI GF63 Thin 9SC-649US
"Don't eat yellow snow!" -Salem
RJARRRPCGP is offline   Reply With Quote
Old 07-28-2010, 01:48 AM   #68
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
Are you sure it was a cat?
Old 07-28-2010, 01:54 AM   #69
ratdude747
Black Sheep
ratdude747's Avatar
City & State: Madison, IN
trust me. you know cat piss when you smell it... it is "unique"
hence why my family has no cat. they ruin couches way too easily like that... that is why so many couches end up by the dumpster...
(Insert witty quote here)
ratdude747 is offline   Reply With Quote
Old 07-28-2010, 10:19 AM   #70
370forlife
Large Marge
370forlife's Avatar
City & State: Kalamazoo, MI
My Country: United States
Line Voltage: 0-120VAC 60Hz
I'm a: Hobbyist Tech
They like carpeted stairs too.
Originally Posted by JFK
The American, by nature, is optimistic. He is experimental, an inventor and a builder who builds best when called upon to build greatly
370forlife is offline   Reply With Quote
Old 08-10-2010, 04:12 PM   #71
RJARRRPCGP
Originally Posted by tazwegion View Post
I can't say I've ever seen a 'roach' in any PC I've owned/or fixed for anyone, I have however found the remnants of a reasonably large spider which had encountered one of the case fans
I would agree with the fact that I never saw a roach.
In Vermont, you're more likely to encounter a fat ass spider than a roach.
And in good Vermont, you're more likely to see daddy longlegs than anything else.
Old 08-10-2010, 04:32 PM   #72
kc8adu
kc8adu's Avatar
City & State: dayton ohio
My Country: U.S.A!
Line Voltage: 12vdc,120/240vac,480vac 3ph on my bench
worst one i had to clean was an ecm from a geo tracker .cover was off and bad cap leakage along with mouse piss was the issue.the seats were gutted too.
kc8adu is offline   Reply With Quote
Old 08-10-2010, 07:04 PM   #73
pentium
pentium's Avatar
City & State: Kamloops BC
My Country: Canada
Bad caps in a tracker?
What kind of torture did that car receive?
Find Nedry!
Check the Vending machines!!
<----Computer says I need more beer.
pentium is offline   Reply With Quote
Old 08-10-2010, 09:50 PM   #74
ratdude747
Black Sheep
ratdude747's Avatar
worried your tracker might be next?
Old 11-21-2010, 07:03 AM   #75
seanc
City & State: Cambridge, UK
Anyone have any comments about cleaning an LGA775 board?
The LGA775 socket is so delicate, any special measures to take - other than not poking the pins with anything?
I have one with the syrupy gunge from a watercooling system all over it.
Cleaned it up, it's working - but the RAM slots are a bit finicky.
seanc is offline   Reply With Quote
Old 11-21-2010, 08:42 AM   #76
shovenose
Send Doge Memes
shovenose's Avatar
City & State: Fairfax, California
I'm a: Forum Junkie
routers/modems have flash memory (like a usb flash drive) built in. cleaning it wont damage it or make it lose te contents.
2001 Suburban, 2010 Escape.
shovenose is offline   Reply With Quote
Old 11-21-2010, 09:35 AM   #77
ratdude747
Black Sheep
ratdude747's Avatar
when you go to clean, find one of the socket covers that comes on the board when it comes out of the box brand new... and remove it and open the socket when it is drying.
Old 11-21-2010, 10:02 AM   #78
seanc
I'll go hunting for some at work tomorrow.
Cheers RD.
Old 02-19-2011, 12:49 AM   #79
Chris Ambriz
I have a Belkin F6D4050 wireless adapter that was given to me it was coverd in solder flux so I took some good old WD-40 o it and blew it off with my air compresser and sure enough it works like new before it wouldn't detect any type of networks or SSID
Chris Ambriz is offline   Reply With Quote
Old 02-19-2011, 11:32 PM   #80
Evil Lurker
Warranty Voider
Evil Lurker's Avatar
City & State: West Tennessee, USA
Absolute best stuff I have have found is Scrubbing Bubbles bathroom cleaner... very gentle and does an excellent job.
Evil Lurker is offline   Reply With Quote
Badcaps.net Technical Forums © 2003 - 2019
