Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Audio Equipment
Old 01-10-2019, 11:23 AM   #1
mykolas
City & State: chicago,illinois
My Country: usa
Default Pioneer VSX-D309 No audio with speakers, ok with headphones
I just got the above unit that works with headphones but not with the speakers alone connected. Speakers check fine. Opened unit up and checked all fuses(glass and micro). Fusible resisters in the preamp and amp section are ok too. When power is pressed, the power relay is heard then about one second later the speakers relay engages. No sound.
Could the PAC012A/013A IC'S have opened up?
Anyone encounter this?
Mykolas
mykolas is offline   Reply With Quote
Old 01-10-2019, 11:44 AM   #2
R_J
City & State: ☻
My Country: Canada
Default Re: Pioneer VSX-D309 No audio with speakers, ok with headphones
Usually if the output ic's are bad the protection will cut in and the speaker relay will not engage, Check that the amp input ass'y board is seated properly
Then check the solder connections on the output ic's
Check if there is output from the suround speakers as well
R_J is offline   Reply With Quote
Old 01-10-2019, 01:09 PM   #3
CapLeaker
Leaking Member
CapLeaker's Avatar
City & State: Atlantic Canada
My Country: Canada
Line Voltage: Ground, 0Hz
I'm a: Hobbyist Tech
maybe the outputs aren't turned on? something stuck inside the headphone jack?
