Go Back   Badcaps Forums > General Topics > General Computer & Tech Discussion
Old 09-30-2018, 02:13 PM   #21
ChaosLegionnaire
HC Overclocker
City & State: Singapore
My Country: Singapore
Line Voltage: 240VAC 50Hz
I'm a: Hobbyist Tech
Default Re: Your Video Card Cooling Mods - Sapphire Radeon HD4650 1G
well, i'd just like to affirm that your testing methodology is sound on both the 2400 xt and 4650.
with the ambient temp of 29C and the max load temp of 37C, u have a delta or rise above ambient of 37-29=8C. since the 2400 xt has a tdp of 20w and the 4650 having a tdp of around 50w, the heatsink has to handle 2.5x the heat output of the 2400 xt. since the heatsink gave a +8C delta above ambient with a 20w tdp heat load, so with 2.5x higher tdp to handle, we have 8x2.5=20C delta above ambient. with an ambient temp of 29C, so we should be expecting temps of around 29+20=49C on the 4650. in practice, your result was a max load temp of 50C.
so i just love it when theory matches up with practice! this means there are no mounting issues with the heatsink and it works perfectly exactly as it should! the above theoretical calculations and momaka's practical testing methodology above should be useful for anyone looking to measure the tdp of a heatsink and how much heat it can handle and what temps u should be expecting. therefore, this negates any newbie mistakes of using an inappropriate heatsink for a video card and ending up with an even worse overheating video card!
let me tell u all about it. recently, i bought a few video cards off junkbay that came with third party heatsinks. thing is, they all had inappropriate heatsinks for the tdp required. i had a 5870 with arctic twin turbo pro. arctic lists the max tdp handling capacity of the twin turbo pro as 125w and the 5870 has a tdp of around 200w! the video card turned out faulty when i tested it and i had to file for a refund.
then i got another 5870, this one has a zalman vf1000. i put a zalman vf1000 on my 6800 ultra before and it struggled to contain the 75w tdp of the 6800 ultra. i dont need to tell u what happens when u try a 200w heat load on a heatsink that can barely handle 75w! i also found that the plastic washers on the back of the card to insulate the pcb from shorting on the spring loaded screws had melted and fused onto the card's pcb. i wonder how hot the gpu ran to cause the plastic washers to melt like that. over 100C?
then i got an asus 4870 dark knight. the dark knight cooler has 4 heatpipes and its design is almost exactly like the vf1000 except upside down, so its an inverted vf1000. the 4870 has a tdp of 150w. no way that dark knight cooler can handle that when the similarly performing vf1000 struggled with 75w tdp.
i find it mind boggling when ppl try to supposedly "improve" the cooling of their video cards but have no idea what they are doing and make the cooling worse instead than even with the stock cooler! so i hope some grey matter use with mathematics and practical physics above, teaches ppl to use the right cooler for your video card!
Originally Posted by momaka View Post
I was getting over 65C on the core (under full load). notice the darkening of the PCB on the back side under the GPU chip? this card came out of a very dusty OEM PC
the 65C u got isnt hot enough to cause the pcb to darken. rather its the most likely cramped oem casing and poorly ventilated oem pc case plus the combined effect of the dust that led to the gpu running even hotter than the 65C u got. i estimate the internal case temps of the gpu running at max load hit over 80C maybe even close to 90C over a prolonged period. thats what caused the pcb to darken.
i highly doubt that gpu will last long. it might need a reflow soon. tho with the 50C load temps now with the new heatsink, the gpu will be lovin' u for givin' it a chill from all the stuffiness it experienced with its previous owner!
I also had some Shin-Etsu thermal compound that I wasnt sure if it was good or not, as it looked rather hard to spread (thick, but not dry).
i have used shin etsu before and i have both the x23 7783d and g751 pastes and yes they are thick and i had to spread them with a spatula. the reason for that is that it has to be thick enough to iron out all the microscopic air bubbles to improve the heat conductivity or sumthing since air is an insulator, not a conductor of heat. i could be wrong tho on why it has to be thick to be good, so dont quote me on that.
i practice my tim application technique by practicing spreading cold butter on bread with a metal butter knife. kills two birds with one stone... or in this case, feeds two mouths with one toast.
Ive played around with these small coolers quite a bit, I can tell you from experience that they are not capable of more than 30 Watts TDP max.
well dont toss em just yet. they should do well for cooling the entry level series of each generation from the 2000 to 5000 series all of which have 20-25w tdp. e.g. 2400 pro/xt, 3450/3470, 4350 and 5450. all of em should have 43mm square mounting hole pattern which fit the cooler. in fact, that 4650 stock cooler should work nice in replacing the stock passive heatsink of my 5450. u should sell that 4650 stock cooler to me! lol!
also, if u dont mind and have the time, u should try that 4650 stock cooler on the dell 2400 xt instead. i wonder how it would perform. i theorise it should perform great! not sure what the ambient temp was when u tested the 4650 stock cooler and got that 65C load temp result but i am going to ass-u-me the ambient temp is 29C. therefore, 65-29=36C delta above ambient. since the 2400 xt has 2.5x lower tdp than the 4650, 362.5=14.4C delta above ambient. with an ambient temp of 29C again, we get 14.4+29=43.4C. so u should get around 43C load temps give or take a couple of degrees with that 4650 stock cooler on your dell 2400 xt. well, if u have some spare time, that would be an interesting experiment to try out! give it a go and lemme see the results! thanks! hehehe...
ChaosLegionnaire is offline   Reply With Quote
Old 09-30-2018, 11:55 PM   #22
brethin
City & State: Owensboro, KY.
Line Voltage: 120VAC 60Hz
LOL killing low profile cards must be the new thing.
brethin is offline   Reply With Quote
Old 10-02-2018, 08:13 AM   #23
momaka
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
When manufactures are too lazy and/or too cheap to put a proper heatsink ... yeah, I'll put whatever I have that is better than their crap. I don't have any low-profile PCs, so I frankly couldn't give a crap about low-profile stuff. Besides, if you are stuffing a 50W+ video card in a small shoebox PC, you're doing it wrong. Most small SFF/USFF PCs already run way too hot inside. They don't need more heat. So a mid-range low-profile video card is a silly idea anyways... unless it really has a properly designed heatsink that exhausts all of the heat outside of the case - and those usually don't come in anything less than a dual-slot and full-profile.
Yes, 65C isn't hot enough for that. But this was the temperature I was reaching only after a few _minutes_ of medium-high load... and at 18C room temperature with _open_ case. Since GPU temperature rises proportionately with ambient case/room air temperature, @ 28C (normal temperature in my computer room for the summer), I expect that stock cooler to easily hit 75C and possibly leveling off around 80-85C or higher with all of the dust it had - which is all hot enough to darken a PCB. (And for the record, I cleaned the stock cooler's fins from dust prior to testing it, so the overheating clearly wasn't from dust accumulation alone).
Meanwhile, this modded cooler keeps the card at around 50C with the same 28C room/case ambient.
I guess as classic car guys like to say: there's no replacement for displacement. In the case of cooling, there's no replacement for surface area (with some airflow, of course).
Not surprised.
Whenever I'm bored, I browse for cheap video cards on eBay. I've been doing that for a few years now, and I've noted that there are video cards with certain coolers that are almost regularly listed for parts or as broken. I saw a few like my Sapphire above as well, so no doubt the stock HS is poorly matched for it. Other regulars are the single-slotted reference HD4850 cards, single-slotted GeForce 8800/9800 GT (which is over 90% what they come with), and GTX 560/Ti with single fan... that's just to name a few off top of my head. There are many more in this list. Most artifacted cards are due to crappy cooling.
Hey, it's a self-reflowing video card! How neat.
The feature doubles as self-drying/baking to remove moisture from air humidity. Awesome!
Thick pastes, I don't spread. I find that the heatsink pressure does a better job at that while pushing out all of the air bubbles indeed. But this only works on GPUs and CPUs with exposed dies. Applying thick paste on a CPU/GPU with a large heat spreader tends to yield not great results, IME. So for those, I use a less viscous (runny/watery) compound.
Already ahead of you there
Though I didn't use the Sapphire HD4650's stock cooler in particular, I did reuse a low-profile PowerColor Radeon HD6670 cooler on one of my HD2400 XT cards. I just didn't take pictures of it, as I didn't think it was that interesting of a card/mod, given how saturated the online market is with used HD2400, 3450, and 6450 cards (they are literally sold by the bucket). In any case, the PowerColor HD6670 low-profile stock cooler is about the same size as the HD2400's reference cooler. But it has much more fins and much thicker base, similar to the Sapphire HD4650 (but still quite inadequate for a 60W TDP). So the temperatures were much lower on the HD2400 - actually very very close to what you calculated/estimated. I don't remember exactly, but I think I was getting indeed around 40-43C load with 28C room ambient and closed case. Stock HD2400 HS in that same case with same room temperature was giving around 60-65C under full load. I'll take some pictures when I take it out for replacement maybe this or next month and also make some graphs. But yeah, that one worked quite well.
And for brethin's sake, I didn't kill a low-profile card with that mod.
Old 10-10-2018, 12:32 PM   #24
ChaosLegionnaire
HC Overclocker
another candidate up for modding is a sapphire radeon 8500le 64mb. i bid on it on junkbay cuz those gf4 ti cards just have overinflated prices! before the seller shipped the item, he said that while testing the item before shipping out, there was some noise from the fan and that he included a second fan in the package.
when i got it and tried testing it on the abit ic7-g, i found that the fan had partially seized with a dry bearing most likely from the noise it made tho it was still spinning very slowly. i still had my dual 80mm fans blowing at it to keep it cool. i tested it in win98 by forcing the driver to see it as a radeon 9000 series card (because the omega drivers i was using no longer support the 8500 series) and it worked fine in many games i tested it with.
i tried removing the fan to lube and clean the bearing but the stator broke apart while i was trying to remove the rotors. grrr! the screw holes for the spare fan the seller provided dont line up with the original fan. there is no way to remove the heatsink because it seems to have been glued down onto the gpu with thermal epoxy. so the only way is to mod the heatsink to attach a more powerful fan onto it.
after cracking my head and having a headache from it for over a week! i finally had an eureka moment. i decided to use cable ties and to use the stator frame of the original fan as an anchor point to secure the cable ties onto. i had to run two cable ties in a "U" manner under the stator frame and then screwed the stator frame back onto the heatsink with the original screws to secure the cable ties onto the heatsink.
took me a few tries to get it right. then i just ran the cable ties sticking up from the heatsink through the mounting holes of the 40mm fan the seller gave me for free. used one of the mini 2-pin to 3-pin fan adaptors i got off aliexpress to connect the fan to the video card fan header.
i ran some game tests with dx8 games to see how hot it ran and if the mod cools well. i also had the usual 140mm fan blowing air over the pci and agp slot area. measuring the temperature of the rear pcb side of the gpu with the scythe ir thermometer, i got 53-54C while gaming. so this means the gpu core probably runs at around 60C at max gaming load. so i wouldnt say it cools well but this is the best it can do since i cant replace the heatsink as its glued down with thermal epoxy.
so anyone have any ideas for removing and weakening thermal epoxy? does acetone work?
File Type: jpg sapphire radeon 8500le fan mod front.jpg (2.40 MB, 15 views)
File Type: jpg sapphire radeon 8500le fan mod left.jpg (2.12 MB, 13 views)
File Type: jpg sapphire radeon 8500le fan mod right.jpg (2.01 MB, 12 views)
Old 10-14-2018, 04:59 PM   #25
momaka
momaka's Avatar
My Country: U.S.A.
No ideas, but I do know temperatures below freezing weaken the epoxy, though. In the past, I've removed the heat spreaders on PS3 GPU chips just with heating the heat spreader to around 60-80C and using brute force to pry it off. But that's always a bit risky.
Anyways, I do have a Radeon 7500 AGP video card with what appears to be the same heatsink as yours (in fact, the whole PCB appears to be very similar to your card with a few minor differences.) And on mine, the fan still works (though it was very noisy and almost stuck when I got it), but I do plan on changing the heatsink on it, just for the sake of having a more quiet card and maybe more reliable too when I use a different fan. I'm thinking to use the same HS as the ASUS V3800M I put in post #2 of this thread.
Old 03-16-2019, 12:33 AM   #26
momaka
momaka's Avatar
My Country: U.S.A.
Talking MSI GeForce GT 430 (N430GT-MD1GD3/OC/LP)
It’s been a somewhat long time since I posted a cooler mod. So let’s do this.
Here is an MSI GeForce GT430 (model N430GT-MD1GD3/OC/LP) video card I found in the recycle bin at a former workplace.
It came with a completely seized fan (50 mm PowerLogic PLD05010S12L). Some of you may have already spotted the glue/adhesive on the fan rotor hub, thinking that this might have something to do with the problem. But really, this is just me taking the picture after I attempted to repair the fan. I say “attempted”, because the fan was one of those sealed sleeve bearing types. Long story short, I did repair it. However, I had to bust its shaft to do that (at least that seemed like the best way to open it at the time - now I have a new and less destructive method… but that’s for another thread perhaps.)
Anyways… regarding the stock heatsink/fan on the MSI GT430 - it was barely enough to keep the card cool. With 70F / 21C room temperature, the GPU core load temps were about 53-54C… and that’s with an under-clocked core of 670 MHz (which I did to keep the GPU stable – more on that below.)
As my repaired fan started getting too wobbly and noisy again (the repair lasted only about a month of daily use ), I knew it was time to replace it for something “better” – even if temporarily. That’s when this “mod” (read: ghetto handiwork) was born:
Yes, folks, that’s half of an Xbox 360 fan! ghetto: Its “other half” has been married to another video card for many years now (a GeForce 7600 GS AGP), and still working!
The Xbox 360 fans are a little noisy, but they push quite a bit of air and have decent static pressure. With that said, it was clear I wasn’t going to run it full tilt @ 12V. Instead, I ran it on 7V (fan wired between 12V and 5V rails for + and GND, respectively.) This actually kept the fan quieter than the original 50 mm PowerLogic fan (which, according to the GPU BIOS, should always be running at 50%, except in cases of elevated temperature, possibly.)
So how much of a temperature improvement did I get with this 70 mm Xbox fan?
- About 5-6C, meaning my max load temps were now around 48C.
Overall, I don’t consider this a very significant improvement. However, given that I was still using the stock Aluminum heatsink, this isn’t bad either. The GT430 is roughly rated for 40-45 Watts TDP. So in all honesty, I expected worse (especially with the stock fan) and was pleasantly surprised to see the temperatures above.
Now, I can’t tell you if this mod will be permanent or if I will replace the heatsink as well. 48C seems all fine with 21C room temperature. But in the summer, of course, I expect my room to hit 28-29C as usual (and peak up to 30C). This means a 7 to 8C rise in ambient temperature. As such, I expect the load temperatures to rise by a proportional amount – i.e. possibly hitting ~55C or more. If more, I will likely mod it. I will also need to see how the card does in terms of stability at those elevated temperatures. Again, this card seems to be stable enough when under-clocked to 670 MHz core (sometimes still crashes after several hours of gaming sessions… which isn’t too bad IMO.), but certainly not at the stock 785 MHz core (30 minutes, typically).
Speaking of which here is a GPU-Z screen of the stock clocks.
It’s interesting to note that this is probably the highest-clocked GT430 video card I have seen anywhere. Most other GT430 cards are set to run at 700 MHz stock, with very few over-clocked to 730 MHz. (Also, is the number of ROPs and TMU's correct above? Techpowerup suggests this card has only 4 ROPs. But the Quadro 600 -equivalent has 8 ROPs.)
Perhaps MSI pushed the clocks too far, and now after a few years, the GPU chip has degraded in such a way that it can’t overclock anymore. Or perhaps not, seeing how I still sometimes get crashes even at 670 MHz core (it just takes a lot more time and loading for that to happen – as stated, at least 3-4 hours of gaming typically.) I guess it's also possible that when the original fan failed, the GPU chip overheated, and that somehow is now affecting the stock core clocks – i.e. a failing GPU chip? Ah well, it is a FERMI GPU, after all – got to expect that to happen sooner or later. This is why it’s important to keep your graphics cards cool.
Old 08-11-2019, 09:41 AM   #27
momaka
momaka's Avatar
My Country: U.S.A.
Post BFG GeForce 7300 GT AGP [BFGR73512GT]
I’m back!
Been busy lately with my new job and also spending most of my free time building up computers with some of the junk I’ve accumulated through the years. But none of that has stopped me from still doing the occasional video card cooler mod.
For today’s post, I have a BGF GeForce 7300 GT, model BFGR73512GT. There’s nothing special about such an old card… except note that this is an AGP video card. I don’t expect most folks to be following up on “trends” with old “retro” PC hardware (I don’t really either), but the value of AGP video cards has steadily gone up in the last few years – especially the more powerful cards (and especially VooDoo cards, if you haven’t noticed. )
So, when I saw this card on eBay for $10 (including shipping), I couldn’t help but snatch it up. This is what I ended up getting:
https://www.badcaps.net/forum/attach...1&d=1565533885
Now, does anyone remember that GeForce 8400 GS PCI card I showed on the last page? If yes, do you see resemblance anywhere? I’ll give you a hint: look in the center of the card.
- The above 7300 GT uses the same crappy cooler as that 8400 GS card with a tiny 40 mm screamer fan. At least the fan wasn’t seized this time, though. In any case, the cooler on this BFG 7300 GT wasn’t adequate to keep the card cool at normal room temperatures, just like the 8400 GS. And here is proof of that:
At 20C (68F) room, the GPU core temperature under full load hit 57C and would have kept going up if I didn’t stop the testing. The 8400 GS did much worse, of course, because it has a higher TDP, IIRC (maybe 5-10 Watts more.)
On that note, I’d guesstimate the G73 core is probably rated for about 25-40W, depending on clock speed (maybe closer to 25-30W for the 7300 GT). The G98 of the 8400 GS is probably at least 30W. Whatever the case, that small finless U-shaped “aluminum bracket” cooler above is certainly not adequate for either card. And you know what this means here: it’s cooler modding time!
Step 1: remove the old cooler and clean the GPU core.
Closer look of the G73 core:
It’s a pretty small die, so be careful if doing your own home-brew coolers. It’s not hard to crack these at all.
Step 2: make/put on a new heatsink/cooler.
You might be thinking this is going to be yet another cut-up, Frankenstein-ed Xbox 360 heatsink… but, nope! Instead, I decided to try something different and re-used the stock heatsink that came with this XFX GeForce 8600 GT video card that I recapped last year (complete post here.) I figured the TDP of the 7300 GT GPU should be low enough for the stock 8600 GT cooler to handle. After all, regular GeForce 8600 GT cards have a TDP of 44W, and the XFX version above is ~60W TDP with the factory OC. Thus, it *seemed* logical that the 8600 GT cooler should be able to handle at least 30W of TDP. Moreover, the cooler from the XFX 8600 GT also matched the stencil outline drawn on the 7300 PCB, as did its screw pattern. So this cooler seemed like a perfect fit every which way… well, almost:
I had to do a bit of cutting/drilling for the GPU’s crystal reference clock to fit. But other than that, it did fit well.
Up next, I put on a 50 mm fan that I had from another XFX 8600 GT (the first one that I recapped.) Of course, I knew this 50 mm fan would be very loud at 12V (and likely not last very long), so I attached a resistor in series with it. I don’t remember what resistance exactly, but I think 100 Ohms. All I remember is that the fan was running on ~6V. Here is the “new” cooler after these mods.
Step 3: Test your handiwork!
In terms of noise, this modded cooler was absolutely silent. Meanwhile, the cooling did improve a bit, but not as much as I would have liked to see. Temperature graphs:
The maximum GPU core temperature peaked around 50-52C after a long session of testing (30 minutes or so) with the same room temperature. Compare that to 57C with the original cooler, and this was with only a few minutes of loading. More than likely, that stock cooler would have gone a bit over 60C if kept at 100% load long enough. Thus, this mod not only lowered GPU temperature by 5C minimum, but the 50 mm fan running at 6V made the card pretty much silent.
Of course, it should be noted here that 20C / 68F is a fairly cool room temperature (at least for my twig structure .) “Normal” room temperature (at least according to most science and physics books even today) is considered to be 25C (77F) and it’s what most hardware is rated for anyways.
Since temperature of the cooler rises proportionately with the room temperature – that is, for a set fan speed… at 25C, even my cooler mod above would make the GPU get a bit hot. That means, an increase in 5C of Ta will result in 5C rise for the GPU (i.e. I’d get around ~56C.) As a matter of fact, I let room temperature go as hot as 28-29C in the summer. So with that kind of temperature, I expected even my cooler mod would have a hard time keeping the GPU under the 60C mark. Thus, it seems like more work is needed on my moded cooler. The first thing I thought of was to put on a fan shroud, so that all of the air from the fan actually goes towards the heatsink and not elsewhere. If you remember from that 8600 GT thread above, this third card did not come with a fan shroud on the cooler. As such, I made my own. Using cardboard, I quickly put this together:
And here it is on the cooler:
https://www.badcaps.net/forum/attach...1&d=1565534244
Not very pretty, but it does the job.
This helped lower the temperature by 1-2C under load. However, I still wasn’t satisfied. So I removed the series resistor for the fan and instead hooked up the fan directly to 7V (by grounding the negative lead of the fan to the 5V rail.) I couldn’t find a convenient test point for the 5V rail, so instead I removed the entire fan connector and had it connect as follows:
Final look on the fan mod…
This yielded the following SpeedFan GPU temperatures:
… which were still not great, considering the GPU again reached close to 57-58C after a few minutes @ 100% load and would have likely gone over 60C if left running over 10-20 minutes. However, note here that the above tests were completed at 82F / ~27.7C room temperature, which is considerably hotter (about 7C) than before. With less demanding games that didn’t stress the GPU to its absolute maximum, I as getting closer to 52-53C on the core.
So overall, this cooler is a decent improvement over the stock one. Despite being used on the 8600 GT (a 47-60W TDP card), I still find it wasn't adequate for this ~30W TDP card. On the plus side, it still only takes a single slot (which is rather rare with my mods. ) And, I was finally able to reuse some of these stock cooler parts that otherwise keep accumulating in my junk boxes.
I just wish this card had implemented some form of fan control that would allow me to crank the fan under heavy load and then go back down to 6-7V in idle mode. Unfortunately, there is no missing or empty circuit on this card that I can fill in to enable this – original fan connector is simply hard-wired to 12V. I’m sure that 50 mm fan would improve the cooling quite a bit at 12V and likely keep the GPU under 60C with the abovementioned room temperature. But it would be loud (I actually tested it before) and it certainly won’t last as long.
Anyways, I’m not all that worried, though, as I still haven’t decided in what PC this card will go in. So with that said, this cooler mod should suffice for now. If I do any revisions on it, I’ll update this thread.
File Type: jpg BFG GeForce 7300 GT AGP [BFGR73512GT] (1).jpg (356.8 KB, 20 views)
File Type: jpg BFG GeForce 7300 GT AGP [BFGR73512GT] (2).jpg (345.6 KB, 19 views)
File Type: jpg BFG GeForce 7300 GT AGP [BFGR73512GT] (3).jpg (154.3 KB, 1 views)
File Type: png BFG GeForce 7300 GT - stock HS and TIM, 68F Ta room.PNG (12.2 KB, 19 views)
File Type: jpg BFG GeForce 7300 GT AGP [BFGR73512GT] (4).jpg (211.3 KB, 2 views)
File Type: jpg BFG GeForce 7300 GT AGP [BFGR73512GT] - GPU chip.jpg (63.0 KB, 2 views)
File Type: jpg BFG GeForce 7300 GT AGP [BFGR73512GT] - cooler mod v1 (4).jpg (82.8 KB, 4 views)
File Type: jpg BFG GeForce 7300 GT AGP [BFGR73512GT] - cooler mod v1 (1).jpg (163.7 KB, 4 views)
File Type: jpg BFG GeForce 7300 GT AGP [BFGR73512GT] - cooler mod v1 (2).jpg (67.5 KB, 4 views)
File Type: png BFG GeForce 7300 GT - 8600 GT HS & 50 mm fan @ 6V, Shin-Etsu TIM, 68F Ta room (2).PNG (11.3 KB, 18 views)
File Type: jpg BFG GeForce 7300 GT AGP [BFGR73512GT] - cooler mod v1 (6).JPG (46.0 KB, 19 views)
File Type: jpg BFG GeForce 7300 GT AGP [BFGR73512GT] - cooler mod v1 (5).jpg (154.8 KB, 3 views)
File Type: jpg BFG GeForce 7300 GT AGP [BFGR73512GT] - cooler mod v2 (2).jpg (172.2 KB, 18 views)
File Type: jpg BFG GeForce 7300 GT AGP [BFGR73512GT] - cooler mod v2 (1).jpg (132.8 KB, 18 views)
File Type: png BFG GeForce 7300 GT - 8600 GT HS & 50 mm fan @ 7V, Shin-Etsu TIM, 82F Ta room (1).PNG (11.8 KB, 18 views)
Old 08-11-2019, 10:49 AM   #28
momaka
momaka's Avatar
My Country: U.S.A.
Default BFG GeForce 7300 GT AGP [BFGR73512GT] - GPU-Z
Oh, and I forgot the GPU-Z screenshot for the 7300 GT above:
The GeForce 7300 GT isnt exactly a powerful card, but its not weak either. In practice, it offers about the same performance more or less as a GeForce 6600 GT, GeForce 6800 XT, and Radeon 9700 non-Pro (depending on the games and 3D features used in the rendering, of course.) Even the 7600 GS is not really that much faster, and thats considered a mid-range card (at least was for its time.) This shouldnt be surprising, considering this card uses the same G73 GPU core as the 7600 GS and GT cards. Only difference is the 7600 cards have 12 pixel and 5 vertex shaders, whereas the 7300 GT has only 8 and 4 (same as a GeForce 6800 XT and Radeon 9700/9800). Otherwise, ROP and TMU count is the same as the 7600 cards with 8 and 12 respectively. As for the RAM: its 128-bit bus. Funny thing is, my 7600 GS AGP actually uses slower RAM than the Apogee branded chips on this 7300 GT (270 MHz vs. 333 MHz). Go figure. However, the higher pixel and shader count of the 7600 GS is what makes it perform slightly better. As for the core clock: the 7300 GT is only 50 MHz slower than the 7600 GS. On that note, since this BFG GeForce 7300 GT uses the same exact PCB as my PNY GeForce 7600 GS card, I had no problems overclocking the core to 7600 GS speeds (400 MHz.) With a better cooler, it might even do 7600 GT core speeds (540 MHz.) From my short experiments with OC on this card, however, performance hardly improved at all when I bumped the GPU core to 7600 GS levels. And Im not sure the RAM will take much OC either, as it already runs rather warm. Thus, the gains from OCing this card didnt seem to matter much. Nevertheless, the 7300 GT is still a very decent AGP card to have around. Should play early and most mid-2000s games at medium-high settings with decent FPS. Probably best matched with a Windows XP machine running on a mid-high-end Athlon XP or Pentium 4. I tested mine on a socket 939 PC with an Athlon 64 3200+ OCed to 2.5 GHz, and the CPU was almost never the bottleneck.
