Go Back   Badcaps Forums > General Topics > General Computer & Tech Discussion
Old 12-16-2017, 12:57 PM   #21
Curious.George
Default Re: Looked at new thermostats, nah I'll DIY this
Originally Posted by evilkitty View Post
when i said what format i mean like a array or sqlite
[{"on":1,"t":20556,"on2":0,"n":1513434346},{"on":1, "t":19832,"on2":1,"n":1513434436}]
on2 would be the aux heating, only set if unit in heat mode, so it doubles as a mode check
maybe i should use both and only dump it to the db every 100 entries or something
maybe i should store the log data on my other rpi
As I said, it depends on the resources that you have available to throw at that aspect of the problem.
If you have a live connection to <something else>, then you can bundle up all of the data that you think may be of interest and spit it out -- and forget it, thereafter.
You can use a database as a "whiteboard" through which you share information among clients. So, you can regularly feed it tuples with "current conditions" (instead of just those times when you actually "take action"). This would allow something else to extract information of interest -- like just how hot the house gets on a winter day in the absence of active heating.
That "other thing" doesn't need to be able to query the thermostat directly (and the thermostat doesn't need to be able to respond to such queries). Instead, just look at the data in the database and extract the information of interest.
The thermostat can also "fetch" its operating parameters from a particular schema. In that way, it need not have a (complex) user interface; let something else (PC?) generate the operating parameters (e.g., pretty user graphics) and stuff them in that schema in an agreed-upon format.
Curious.George is offline   Reply With Quote
Old 12-28-2017, 12:46 AM   #22
RJARRRPCGP
City & State: North Springfield, Vermont
Line Voltage: 118-127V 59-63.5 Hz-> actualizar: pérdido de voltaje
the heating system at work is like you described, run 30 seconds off 30 second; rinse, wash, and repeat
Sounds just like a POS well pump that keeps losing pressure. A house in the boonies that I was in from September 1, 2004 to March 5, 2008, used to be connected to the old well, which had a pump like that, but a brand new well was installed in the first quarter of 2008, or the forth quarter of 2007. Good riddance!
Asus P6T6 WS Revolution
Core i7 Extreme "Bloomfield" 965
Asus Strix GeForce GTX 970
Windows 7 SP1
SoundBlaster ZXR
Corsair TX850M PSU
Looks like I have a laptop that kills a desktop PC!
Received on November 4, 2019:
MSI GF63 Thin 9SC-649US
"Don't eat yellow snow!" -Salem
RJARRRPCGP is offline   Reply With Quote
Old 12-28-2017, 05:57 PM   #23
redwire
City & State: Alberta
My Country: Canada
I watch TV and the heat from it (240W & CCFL) causes the thermostat to think the house is warmer. The two are 10 feet apart
Watch a movie and freeze.
redwire is offline   Reply With Quote
Old 12-30-2017, 07:03 PM   #24
evilkitty
evilkitty's Avatar
City & State: VA
Line Voltage: 120VAC 60Hz
Here are a few solutions/workarounds
  • Move thermostat
  • Move TV
  • Get LED TV
  • move temp sensor
  • sit closer to TV
10ft seems like it would be enough space...
evilkitty is offline   Reply With Quote
Old 02-04-2018, 06:47 PM   #25
evilkitty
evilkitty's Avatar
City & State: VA
I made the last couple years worth of adjustments public today
https://github.com/GM-Script-Writer-..._Pi_Thermostat
images and hardware info here:
https://github.com/GM-Script-Writer-...ter/html/notes
Badcaps.net Technical Forums © 2003 - 2020
