Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Audio Equipment
Old 09-30-2015, 04:09 AM   #1
julius22
City & State: Copenhagen
My Country: Denmark
Default Altec Lansing MX5021 silent, need Schematics..
Altec Lansing MX5021 silent, except for some hum.
The output amp ICs seems to work.
Does anybody have schematics for the amplifier in this unit?
julius22 is offline   Reply With Quote
Old 09-30-2015, 07:58 AM   #2
Khron
City & State: Valkeakoski
My Country: Finland
Line Voltage: 230VAC 50Hz
Default Re: Altec Lansing MX5021 silent, need Schematics..
What test equipment do you have available?
Khron is offline   Reply With Quote
Old 10-01-2015, 02:40 AM   #3
julius22
My Country: Denmark
I have a range of multimeters, Oscilloscope, Audio generator, Portable One Plus.
I understand, the "remote" has a 2-wire serial data connection to the amplifier, that communicates with the "TDA7433 Basic Function Audio Processor".
May be the problem is here. (?)
The Power supply seems to be ok.
Old 10-01-2015, 04:44 AM   #4
Khron
My Country: Finland
I was just thinking that if you apply a signal to the input, you could scope it out along the op-amps in the audio path, and see where it stops.
If there's that processor in there, though... There is at least some chance the problem might be somehow related to it. It would definitely be worth scoping its inputs & outputs, though.
http://www.st.com/web/en/resource/te...CD00000878.pdf
Old 10-10-2016, 01:46 AM   #5
ant3202
ant3202's Avatar
City & State: Singapore
My Country: Singapore
Line Voltage: 230V 50Hz
many users feedback that ST TDA7433D seems to fails alot.
im waiting for the parts to come....
ant3202 is offline   Reply With Quote
Old 01-01-2017, 11:23 PM   #6
ant3202
ant3202's Avatar
Update, I had replaced the ST L7809CV and JRC 7909A IC chip,
obviously the IC is driving hard, as the PCB board is discolored at that area.
replaced with a fresh IC and added heatsink.
now the audio is back.
Old 12-21-2018, 09:31 AM   #7
theATeam
My Country: Denmark
I know this is an old thread, but it is the closest thing to a solution, i have been able to find.
I have two sets of the Altec Lansing's MX5021. One of them doesn't work. The other one still works.
There are two ICs located on the back of the PCB. The first one is ST TDA7433D located at U8, which is partially melted on both of my speaker-sets, but the label is still readable.
The second one is unidentifiable, since it has melted/ deformed to a degree where the model-number is unreadable.
Could anyone tell be the model-number of the IC located at U13 on the back of the PCB?
This would really make my day. I love theses speakers, but i can't find any schematics or high-res pictures of the PCB online.
theATeam is offline   Reply With Quote
Old 12-21-2018, 09:50 AM   #8
Andrew F. Ali
Andrew F. Ali's Avatar
City & State: Point Fortin
My Country: Trinidad & Tobago
Line Voltage: 125VAC 60Hz
I don
t think the ICs melt or I've never seen an IC melt before. I think what you are seeing is probably the varnish they spray on finished circuit Bds at the factory. ICs or semi-conductors would pop open and burn.
Andrew F. Ali is offline   Reply With Quote
Old 12-22-2018, 02:13 AM   #9
theATeam
My Country: Denmark
I have a few pictures. It may be varnish that covers the first one (U13), but the TDA7433D (U8) looks like it has been too hot.
They designed the speakers so that these two ICs are literally covered in rockwool, so i'd image they can accumulate some heat during longer use.
Old 12-22-2018, 06:35 AM   #10
Khron
My Country: Finland
If heat was indeed an issue for those chips, they would've shown marks in the middle, where the actual silicon die sits, not on the edges
https://thumbs.dreamstime.com/z/ic-r...h-47481330.jpg
That's more likely flux residue, or something external. I doubt they'd bother conformal-coating dry-environment consumer stuff like these.
Either way, the first commandment of troubleshooting electronics is "Thou shalt measure voltages"
Old 12-22-2018, 03:44 PM   #11
budm
budm's Avatar
City & State: S.F. Bay area
Line Voltage: 120V 60Hz
"the first commandment of troubleshooting electronics is "Thou shalt measure voltages" +10
Old 12-31-2018, 01:45 AM   #12
ant3202
ant3202's Avatar
Hi and what issues on the faulty one?
No power or no sound?
U13 - ST 074C
https://www.st.com/resource/en/datasheet/cd00000489.pdf
Badcaps.net Technical Forums © 2003 - 2019
