Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Audio Equipment
Old 09-09-2015, 06:44 PM   #21
DjKrish
City & State: SG
My Country: SG
Default Re: Pioneer VSX-520-K Protection problem
Originally Posted by tibimakai View Post
Maybe a reset at this point, it wouldn't hurt either.
Haha tried that already, still same with DC msg.
DjKrish is offline   Reply With Quote
Old 09-09-2015, 11:05 PM   #22
rievax_60
City & State: mackay
My Country: australia
Line Voltage: 240
I'm a: Hobbyist Tech
Most amplifiers rely on a few certain screws to ground the input sockets to the rear panel.
If these screws don't provide a contact, the amp wont work properly.
rievax_60 is offline   Reply With Quote
Old 09-10-2015, 07:34 AM   #23
DjKrish
City & State: SG
My Country: SG
Its all tight.
Old 09-10-2015, 07:35 AM   #24
DjKrish
City & State: SG
My Country: SG
Can i get some assistance on CP107 on how to measure those pins? I believe B+ and B- should be 100V. But when measure B+ and AGND, there's reading about 50v, is that a leak of DC on main board?
Old 09-10-2015, 08:28 AM   #25
rievax_60
Line Voltage: 240
Measuring 100v between B+ and B- rails is normal if the rails measure +50v and -50v respectively to ground.
Old 09-10-2015, 08:39 AM   #26
DjKrish
City & State: SG
My Country: SG
Ok i have measured the amp block thoroughly and there's no faulty components on it but when i plug it in to main board via CP107, then there's DC leak via CP203 on speaker assy. Almost all the legs has DC leaking. My friend said, if i pull out CP107 from amp to main, it will disconnect the amp but the receiver will turn on fine provided theres no shorts on main board to cause a dc protection. Looks like the DC is still present on speaker assy relays. Sighs
Old 09-10-2015, 08:48 AM   #27
rievax_60
Line Voltage: 240
What DC voltage reading are you seeing? And is it on all amplifier outputs?
Old 09-10-2015, 09:02 AM   #28
DjKrish
City & State: SG
My Country: SG
I see dc around 47v on FR,FL,C,SR,SL connector that goes to speaker assy
Old 09-10-2015, 09:16 AM   #29
rievax_60
Line Voltage: 240
Look for something common to all amplifiers like the - rail that feeds the emitters of the voltage amplifier transistor via R227 10 ohm. And also the +12v rail that goes to the 7.5k resistors that connect to the input transistors' emitters.
Old 09-10-2015, 09:47 AM   #30
rievax_60
Line Voltage: 240
If you find nothing wrong then measure the voltage at both ends of the input capacitors, C206FL, C206FR.
Old 05-10-2016, 04:31 AM   #31
DjKrish
City & State: SG
My Country: SG
Hey folks, im back after a long time due to work load. OK as for updates, i manage to fix the amp as on the power amp side, a couple of regulators seems faulty triggering the protection circuit. Now the amp powers up perfectly, all relays clicking fine.
BUT, I measured using DMM @ 200mV setting,
Left speaker output there's -31.3mV present while the right side -7mV dc offset present. What do i do now? Checked the big caps, they read just fine and measure as it should using a cap meter.
All the driver amp transistors seems to be fine as well as none blown or short.
Update : All surround speakers and center speakers, L&R speaker outputs are working perfectly fine with all under 10.0mV. Weird.
Could it be the big caps failing intermittently?
Old 05-10-2016, 08:17 PM   #32
DjKrish
City & State: SG
My Country: SG
The amp at cold start, right channel has at least -30mV and left shows -0.00mV. After about 10 or 20 minutes, right channel resets back to 0.00mV. May i know why is this? Anyone can help?
Old 05-10-2016, 10:52 PM   #33
budm
budm's Avatar
City & State: S.F. Bay area
Line Voltage: 120V 60Hz
30mV offset is not going to trip the speaker protection relay, the trip point is usually around a Volt or two to trip the protection circuit.
Old 05-11-2016, 01:20 AM   #34
DjKrish
City & State: SG
My Country: SG
But is it normal for -30mV to present @ speaker terminal? Ive seen + and above dc offset, but mine is minus offset. Thats the weird part. Sound wise no problem, still kicking good.
Minus 30mV present when volume at zero with no signal input and speakers unplugged. Ive let it run for couple of hours, still showing -30mV. Only the right channel. Left seems fine.
Old 11-04-2016, 04:46 PM   #35
kevwag
City & State: Bournemouth, Dorset
My Country: England
That's an interesting theory, but it would have to be a pretty bizarre set of circumstances for poor earthing on an input at the pre-amp end to cause DC on the output stage of the power amp!
That said, I just managed to cause DC on the INPUT of my VSX-520, taking out C206C with a loud bang! This is a good example why you should use the service manual, even when you're experienced and know what you're doing. I dived in without the manual, replaced the output transistors and also needed to replace the protection transistors as they were also dead-short. It has been well over a decade since I worked on electronic repair of this type and it seems things have moved a long way...
The protection trannies were marked C3200 and A992, which, back in my day you could have safely assumed would have meant 2SC3200 and 2SA992 but not now apparently! I should have used KTC3200BL and KSA992F - these codes didnt exist back when I did this for a living! I Feel a bit silly for not having checked - lesson learned the hard way!
I don't need the centre channel right now so I'm going to isolate B+ and B- for that channel, pull out the incorrect trannies and try again, if the rest still works I can order the right parts and use it 4.1 until they arrive lol
kevwag is offline   Reply With Quote
Old 09-12-2017, 08:27 AM   #36
srt1
City & State: calicut
My Country: india
Can you explain what cause the DC offset on Speaker output?
srt1 is offline   Reply With Quote
Old 09-12-2017, 08:40 AM   #37
srt1
My Country: india
Hi i Hav pioneer VSX 522 it have DC offeset on all channel can i checked Can you explain what cause this DC offset
Old 09-12-2017, 08:57 AM   #38
rievax_60
Line Voltage: 240
What voltage and polarity are the offsets?
Old 09-12-2017, 10:07 AM   #39
srt1
My Country: india
its around 54 volt (positive polarity) with ground
Old 09-12-2017, 01:19 PM   #40
rievax_60
Line Voltage: 240
If the input differential transistor pairs lose Emitter current, the amplifier outputs will go to a high positive voltage. There is a 12v rail that is common to all channels.
