Go Back   Badcaps Forums > Motherboards with Bad Capacitors > All Others Motherboards
Old 02-03-2014, 02:51 PM   #1
MikeM84
City & State: Patchogue, NY
Default Need help - 3 Caps replacement for EVGA 780i SLI motherbord
So I was having issues with my computer lately, tested my gpu/ram, nothing. Formatted, put a fresh copy of win 8 in, still blue screening, stress tested the cpu and found core0 failing, got the cpu today, went to put it in, and found 3 blown capacitors.
So I just need help finding replacements for them, I think I found them and just wanted assurance, thanks.
2x blown: 6.3v 2700uf MFZ T0712 105C PET
1x blown: 6.3v 1500uf SAMXON GC(M) W4A 105c8
and these are the caps I found:
Nichicon 2700uF 6.3v Ultra Low ESR Electrolytic Capacitor:
http://www.badcaps.net/store/product...roducts_id=149
Nichicon 1500uF 6.3v 10mm Ultra Low ESR Electrolytic Capacitor:
http://www.badcaps.net/store/product...roducts_id=147
Will these work? I also found some on another site if not, here:
6.3v 2700uf: http://goo.gl/OkSLhw
6.3v 1500uf: http://goo.gl/UGwWQh
Thank you for the help.
MikeM84 is offline   Reply With Quote
Old 02-05-2014, 08:08 PM   #2
Heihachi_73
City & State: Melbourne
My Country: Australia
Line Voltage: 240VAC 50Hz
Default Re: Need help - 3 Caps replacement for EVGA 780i SLI motherbord
Ouch, something must have gone bad to kill a Rubycon like that, even if it is a 2007 cap. If it wasn't a chain reaction caused by those Samxons, check the power supply, as it could be worse in that, especially if it's the original one. I'd be expecting to see a few dead Teapo caps or similar brands in a seven year old PSU...
If not, maybe Windows 8 really is bad enough to cause hardware to become suicidal.
Heihachi_73 is offline   Reply With Quote
Old 02-05-2014, 08:21 PM   #3
MikeM84
I run a pretty hard overclock on the system, wondering if that caused it. But I'll check the PSU too, good call before firing up the board with new caps.
Old 02-07-2014, 07:46 PM   #4
momaka
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Hobbyist Tech
Check PSU and report back (better yet, post some pictures of it or at least tell us what brand and model it is).
It may also be that your overclock is pushing the motherboard too far, making the MOSFETS and coils for the CPU VRM overheat, thus causing the caps to blow. If that's the case, you might have better luck if you replace those electrolytic caps with polymers. However, if the CPU VRM is running so hot that it cooks caps, you may also have to implement something to cool it down (a fan directed down on the board in the CPU VRM area would do). Hot-running MOSFETs and coils are never a good thing!
Which leads me to this... the problem could also be caused simply be inadequate cooling on the motherboard. Many CPU coolers nowadays pull air from one side and push it out the other parallel to the board. While this does indeed allow for a better overall cooling in the PC case, it may not provide adequate cooling for some of the components on the board.
Old 02-10-2014, 04:13 PM   #5
MikeM84
Ok so I took apart the PSU and didn't find any problems. Here's some pics.
Thermaltake W0106RU 700W Complies with ATX 12V 2.2 & EPS 12V version SLI Certified 80 PLUS Certified Modular Active PFC Power Supply
Old 02-10-2014, 11:02 PM   #6
momaka
momaka's Avatar
My Country: U.S.A.
I see many Samxon GF. Not a very good thing. While this may not be the cause of your problem and yours still appear to be good, just keep in mind that they do fail a lot.
That said, I'm more inclined to think your caps probably failed because of reason 2 and 3 I gave above (or a mix in between). So try turning down that overclock a little or try adding a fan to keep the CPU VRM cool (after replacing the caps, of course).
Old 02-13-2014, 02:29 AM   #7
MikeM84
Keeping the cpu cool shouldn't be an issue now that I've installed a corsair h60 with in push/pull config, runs around 30c now.
And the VRM has a built-in copper cooling radiator:
http://images.anandtech.com/reviews/...i/evga_lrg.jpg
Old 02-13-2014, 09:31 AM   #8
Per Hansson
Per Hansson's Avatar
City & State: ----
My Country: Sweden
Line Voltage: 230v 50Hz
Just keep in mind that a closed loop water cooler like that removes allot of airflow that would otherwise go over the mainboard.
On my own system I installed a fan cooling the motherboard for this reason (I have a custom built water cooler)
Without it the motherboard VRM heatsink got too hot for my comfort zone...
But it looks like on one of the pics you already have a fan on the VRM heatsink?
If so you should be good, just make sure it makes good contact with the VRM's
Old 03-10-2014, 06:52 PM   #9
Agent24
I see dead caps
Agent24's Avatar
City & State: Hiding inside a plated-through hole
My Country: New Zealand
Line Voltage: 230VAC 50Hz
If the PSU has Samxon GF, replace those capacitors too, they're horrible anyway.
-David VanHorn
Agent24 is offline   Reply With Quote
Old 03-10-2014, 08:14 PM   #10
kc8adu
kc8adu's Avatar
City & State: dayton ohio
My Country: U.S.A!
Line Voltage: 12vdc,120/240vac,480vac 3ph on my bench
yes as the samxons are on borrowed time.cwt does a good job of selecting crap parts.they have a near perfect track record of it!
kc8adu is offline   Reply With Quote
Old 09-15-2014, 01:33 PM   #11
Philly Cheese Steak
Philly Cheese Steak's Avatar
City & State: NEW YORK OR TAXLAND
Line Voltage: 120VAC
You over clock but cant clean your system, and you wonder why the caps blew? Clearly HEAT is your best friend next to dust......................................
SB-E 3930K
Asus X79-Deluxe
Asus 2X GTX 780 Ti DCII
Gskill 16GBRip JAWS@2400
Intel 520'S Raid 0
Corsair AX1200
Philly Cheese Steak is offline   Reply With Quote
Old 10-01-2014, 04:51 PM   #12
MikeM84
The system is not that dusty at all. Unless you'd like me to get down on hands and knees with a toothbrush and clean every part.
The dustiest part was the inside of the PSU. Which didn't blow anything.
Anyway,
It's been awhile since I ordered the replacement caps, I have them, but am finding it difficult to replace them. I don't think evga used tin solder. I've been through a bunch of soldering irons, up to 70w 1200F, and they wont un-solder.
Any advice for swapping these? Should I take the board to an electronics shop or something?
Old 10-01-2014, 06:26 PM   #13
Agent24
I see dead caps
Agent24's Avatar
It's hard to do multilayer boards if you have never done it before. Preheating and good tools help a lot. Huge amounts of heat do not necessarily help, as they can often just make things oxidise faster and become dirty, and make everything harder.
Practice on some old boards if you need to. Or yes, you could take it to a shop and get them to swap the parts for you.
Old 10-02-2014, 08:40 AM   #14
diif
City & State: Midlands
My Country: England
I find a dab of flux on each of the legs helps with heat transfer, and I usually add a bit of solder to aid in desoldering. I heat one leg and then gently pull on the cap away from heated leg , then heat the other leg and pull the other way. Repeat a few times and the cap can be "walked" out.
diif is offline   Reply With Quote
