Go Back   Badcaps Forums > General Topics > Custom Tweaks, Modifications, and Revisions
Old 01-10-2019, 06:50 AM   #501
stj
stj's Avatar
City & State: Europe
Default Re: The ghetto mod thread
we know what it's for, question is why you didnt get one from china for under 2$??
radio-programming cable - kenwood compatable.
stj is online now   Reply With Quote
Old 01-10-2019, 09:59 AM   #502
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
Mainly shipping time, and well, looks like RS232 versions can't be had that cheap...
eccerr0r is online now   Reply With Quote
Old 01-10-2019, 10:59 AM   #503
stj
stj's Avatar
i would pay 2$ just for the molded plug & cable.
infact that reminds me, i need to get a spare mic/earpiece for the cable to make an FRN interface.
http://www.freeradionetwork.eu/
Old 01-10-2019, 02:20 PM   #504
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
That Kenwood merged 3/32 1/8 plug is simply awful. Hate that "feature" to make things "easier" to connect...grr. Alas yes "after the fact" it is a one-plug deal to hook up the programming cable.
So it actually works for Kenwood too despite being for Baofeng? My TR-2500 is definitely not one of those programmable via serial but interesting that Baofeng even copied things down to this level...
Old 01-10-2019, 10:57 PM   #505
stj
stj's Avatar
kenwood first invented the 2.5mm+3.5mm combined plug,
almost everybody else slowly started adopting it - other than the mofo's at Motorola who still want to invent a different cable for every model of radio!
Old 01-11-2019, 12:34 AM   #506
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
Well they invented it for their speaker microphones and headsets, but did they first design the pinout for their serial programmable radios that's used on all these baofengs?
Yeah apple^H^H^H^H^H^H motorola needs to stop making different cables...
Old 01-11-2019, 05:00 AM   #507
stj
stj's Avatar
programming has always been through the audio pins - it may go back to the days of 8bit computers that loaded software through audo cables.
Old 01-11-2019, 10:34 AM   #508
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
But with the exact same pinouts and levels?
The baofeng seems to use TTL (0V-referenced, positive going) compatible signals on the 3/32 and 1/8" plugs, which is not very robust for long distances, though the speed is fairly low...
BTW the pinout is weird - microphone Shield connector is the data in/receive TTL pin. The Ring connection of the speaker jack is the transmit...
Old 01-11-2019, 01:05 PM   #509
stj
stj's Avatar
i know the pinout, i dont know why the "shield" is not earth but it could be because they consider the pair a single coonection - so it would be a waste to double it up.
Old 01-11-2019, 02:09 PM   #510
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
Oh screw this. My Kenwood TR-2500 3/32" and 1/8" jacks are closer together than the Baofeng 3/32" and 1/8" jacks, so they are not physically compatible with each other though I think they're electrically compatible including PTT...
Old 01-14-2019, 11:41 AM   #511
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
Winner!
https://forums.radioreference.com/th...-fails.381842/
Old 01-23-2019, 06:30 PM   #512
madan1
City & State: Sofia
My Country: Bulgaria
Back to basics ( and of course it is a temporary fix.. "temporary" )
madan1 is offline   Reply With Quote
Old 01-23-2019, 09:51 PM   #513
stj
stj's Avatar
shame about the track damage.
why is there so much flux on the diodes??
Old 01-23-2019, 10:22 PM   #514
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
Seal of approval
Kester "44" tends to leave a lot of flux around, but better plenty of flux than not enough flux...
Old 01-23-2019, 10:38 PM   #515
momaka
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
We need Electroboom here to say That's a FULL BRIDGE RECTIFIER!
Regarding the temporary part... as my dad would say about a friend of his who borrow his car wrenches: Oh he didn't steal them from me. He just borrowed them "temporarily"... for almost 20 years.
Old 01-24-2019, 07:18 AM   #516
madan1
City & State: Sofia
The board is made out of cardboard... as soon as it smells a hot iron and the tracks start to run away.. no, realy.. cambridge audio - engineered in the UK, made in the PRC with the crappiest boards available! Even straight out from the factory, it had damaged tracks and solder blob bridges.
And in addition, I had to remove/install several times the original bridge rectifier and even swap it with the other one ( next to my ghetto fix ), before being sure it had failed. The rectifier was not dead, but partially working.. it was outputting 100% of the negative rail and about 70% of the positive.
About the flux - I just did not care to clean it.
Old 01-24-2019, 10:10 AM   #517
stj
stj's Avatar
cambridge audio
says it all.
i remember them - paxoline pcb's and probably built in a shed by housewives - forget china!!
i worked for a very high-end company in the u.k. once,
they had a u.k. pcb stuffing facility they actually refered to as the chicken coup!!!
Old 01-24-2019, 04:25 PM   #518
madan1
City & State: Sofia
But do you know what's the funny thing? They've put a big ass 1.4KW toroidal transformer which weights a ton! This is an expensive hardware part and most manufacturers tend to save money from it. Such transformers can be found only in the high end products of the other companies ( onkyo, denon, yamaha... ). I really do not see the logic here - "let's use a 100 buck power supply, but let's cut $10 from the boards.. yeah... great idea!"
Oh, and another funny thing - the sucker sounds better than my high-end yamaha aventage... go figure
Old 01-24-2019, 08:13 PM   #519
stj
stj's Avatar
toroids are seen as a sign of quality - put a toroid in and show open-case photo's and audiophyles will pay more.
