Badcaps.net Forum
Go Back   Badcaps Forums > Motherboards with Bad Capacitors > Other Devices with Bad Capacitors
Thread Tools Display Modes
Old 09-27-2011, 12:05 PM   #21
Brice
Default Re: APC Back-ups RS 1500 Dead
Quote:
Originally Posted by AquaSonic View Post
Hi again. No toasty, nothing at all. There is a fan but it is completly dead.
I forgot to tell you that i am using the 220v version of it (i don't know if it makes any difference in the A/C part).
Do you have this ups? Can i give you some pictures to ask you to measure the current there?
The white Rely (at the A/C part next to the 2 black ones) is the component i can't understand whether it is good or not. Here is its datasheet http://pdf1.alldatasheet.com/datashe...68-24-2CE.html
This one is the 8 contact version.
From the downside it looks like ths
1 2 3 4
5 6 7 8
(there is a huge space between 3 - 4 and 7 - 8 but it won't show in the forum)
The 4 and 8 pins are the 700Ohm DC coil, which meters ok.
The 1 and 5 pins are the A/C input pins.
The 2-6 and 3-7 from what i understand output 230v when there is 25v on the 4-8 pins.
4-8 pins point ~25v when connected to ground individually (4 & gnd / 8 & gnd).
1 and 5 when tested together point 230v, which is ok.
2-6 and 3-7 are dead. BUT! When they are individually tested with Phase or Neutural, they produce about 110v.
So either i need to refresh my psu testing skills or this relay seems bad to me.
I hope you can follow my post
Hi!
I have a similar problem. I returned home from vacation and my RS 1500 was completely dead. I have opened it and replaced all the big caps but still no sign of life, exactly as you mentioned in your post.
Did you fix yours?
Br.
Brice is offline   Reply With Quote
Old 03-11-2013, 09:53 AM   #22
arielleon305
City & State: mendoza
My Country: argentina
I'm a: Knowledge Seeker
Components were burned in my APC RS-1500, but I can not read their values​​. There is a board diagram of the board?
The components are D35, Q41, R73, R37 (I can't read)
arielleon305 is offline   Reply With Quote
Old 05-30-2013, 11:43 AM   #23
eelliott
City & State: Cody, WY
My Country: USA
Line Voltage: 120VAC 60Hz
arielleon305,
Photo attached...
D35 = "A7W"
Q41 = "1AM"
R73 = "2000"
R37 = "2000"
My board is labeled 640-0253E in the bottom right corner (when the big transformer is in the upper right).
My RS 1500 (tall, narrow, beige) is not dead but has started constantly cycling between on-battery and on-AC. None of my other UPS's are unhappy with the incoming AC, which seems to be steady at 122V. There are no expanded caps or burn spots on the board or components. The two 40A fuses are OK. I'm debating my next steps.
Anyway I had it open and thought that you might still be able to use the info.
eelliott is offline   Reply With Quote
Old 08-29-2013, 03:00 PM   #24
jetelina
City & State: Vienna
My Country: Austria
Quote:
Originally Posted by eelliott View Post
arielleon305,
Photo attached...
D35 = "A7W"
Q41 = "1AM"
R73 = "2000"
R37 = "2000"
have you found out why is this happening?
- I have also APC 1500 RS 220V - without display.
- The thing that happens is when I power it up it stays on battery and does not detect current from wall.
- It's plugged into wall. I pusshed circuit breaker several times. Set UPS sensitivity to low.
- Actually it happes the same as on this YouTube video
http://www.youtube.com/watch?v=lioxJe0UdxY
Any ideas?
jetelina is offline   Reply With Quote
Old 08-29-2013, 03:41 PM   #25
eelliott
My Country: USA
Quote:
Originally Posted by jetelina View Post
Any ideas?
No ideas. I was unable to locate a service manual or even a schematic. And because none of the caps were bulged/discolored the solution was not clear in the case of my board.
I replaced the unit with an APC SMC1500. BTW, I wasted time exploring APC's swap program (I've forgotten APC's name for that program) but it was less expensive (and less hassle) to buy a new unit from a retailer rather than dealing directly with APC. (USA. I don't know if that holds true for other countries.)
Old 08-29-2013, 06:21 PM   #26
shovenose
Send Doge Memes
shovenose's Avatar
City & State: Fairfax, California
My Country: USA
I'm a: Forum Junkie
I have the version with LCD and its currently not in use so if it can be of assistance...
shovenose is offline   Reply With Quote
Old 10-04-2015, 08:08 AM   #27
jaykcee
City & State: Portlaoise
My Country: Ireland
Not wanting to appear stupid ( which I can easily manage ) ..
In troubleshooting these APC Ups .. what voltage should I be seeing across the charging leads /battery terminals with zero load if its healthy .. ?
( 2 x 12volt 20amp batterys , 1250VA Ups )
jaykcee is offline   Reply With Quote
Old 10-04-2015, 08:24 AM   #28
stj
stj's Avatar
City & State: Europe
My Country: some shithole run by Israeli agents
I'm a: Professional Tech
about 20% higher than the battery's are rated at.
so about 28v i suspect.
stj is offline   Reply With Quote
Old 10-04-2015, 11:55 AM   #29
jaykcee
My Country: Ireland
Hmmm That sort of confirms my suspicions ..
Its definitely not supplying a charging voltage..
I've had people tell me to just buy another set of batterys , but it seems to have killed the last set of new ones and buying more seems like a waste of money ..
Whats the most likely thing to fail in the charge circuit ..?
I'm getting to the sad conclusion it may be an "ex-Ups"
Old 10-11-2015, 06:58 PM   #30
CapLeaker
Leaking Member
CapLeaker's Avatar
City & State: Atlantic Canada
My Country: Canada
Line Voltage: Ground, 0Hz
I'm a: Hobbyist Tech
How long where the old set of batteries in for?
CapLeaker is offline   Reply With Quote
Old 10-12-2015, 02:39 PM   #31
budm
budm's Avatar
City & State: S.F. Bay area
My Country: USA
Line Voltage: 120V 60Hz
Good clear pictures of inside the unit and the boards?
__________________
budm is offline   Reply With Quote
Old 06-03-2016, 01:42 PM   #32
Zorix
City & State: Fort Myers
My Country: USA
I know this topic is a little bit old but I think this could help. A common problem in the BR1500 model is that two surface mount aluminium electrolytic capacitors (C40 and C41) responsible for the -8v supply to the line sense circuit is marginal or failed. On mine, they read correct 22uF value but fail on ESR test. Replacing either or both of these should fix the on battery always or constant switching to battery.
I also have a PDF of the schematic for the board model 640-0253E. I don't know about this forum's policy though. APC has shut down sites providing schematics in the past.
Zorix is offline   Reply With Quote
Old 07-23-2016, 10:21 PM   #33
runderwo
Back-UPS XS 1500 was repaired by replacing all 22uF SMD electrolytic caps. There are five of them and they were reading anywhere from tens of ohms to infinite ESR. Symptom was failure to charge battery and eventually failure to power on at all emitting only a chirp on attempt.
runderwo is offline   Reply With Quote
Old 07-28-2016, 01:19 AM   #34
fzabkar
My Country: Australia
Line Voltage: 230VAC 50Hz
Isn't eserviceinfo.com a Bulgarian site? Would the Bulgarians give a damn? Maybe we could see if they have the schematics ...
There are a few schematics at ElektroTanya also ...
fzabkar is offline   Reply With Quote
Old 08-15-2016, 11:31 AM   #35
cassava
City & State: agra
My Country: india
just change the battery and it will work
cassava is offline   Reply With Quote
Old 01-15-2018, 02:38 PM   #36
andmars
City & State: Dublin
My Country: Ireland
Default
Had to register just to say thanks, you were absolutely spot on!
For the last six months i had noticed any time my RS 1000 was powered off it took multiple attempts to start up before it would switch to AC power. Over the last few weeks it had started rapidly switching to battery and back very quickly. Always in the middle of the night you would hear a clickity clack, clickity clack, clickity clack from the next room and i would have to get up and power it off. Then power cycle it multiple times the next day before it would switch to AC.
I tried replacing all the regular electrolytics which made no difference, but it was probably no harm in doing them anyway. Then i found your post and changed the C40 and C41 SMD's as per your recommendation and it worked perfectly. Just to future proof it i replaced the other SMD's, so thank you, a combination of your wisdom and my stubborness it should serve me well for another decade or so.
P.S. Would love a copy of the schematic if you could PM me a copy?
andmars is offline   Reply With Quote
Old 06-09-2018, 07:27 AM   #37
sseverus
A common problem in the BR1500 model is that two surface mount aluminium electrolytic capacitors (C40 and C41) responsible for the -8v supply to the line sense circuit is marginal or failed . . . Replacing either or both of these should fix the on battery always or constant switching to battery.
Thanks. My APC was immediately switching to battery whenever turned on. I replaced C40 & C41 as you suggested and it now works fine. Thanks again.
sseverus is offline   Reply With Quote
Old 12-03-2018, 02:28 PM   #38
cpumech
City & State: Rogue River,Oregon
My Country: USA
Also another thanks to you all, I used my Ungar heat gut to locate the caps last week, and Just wanted to confirm that you were right, when I heated the caps with the gun It works fine, cooling them off with the Freeze mist = Fail, So we are in agreement, thanks again. Peace
cpumech is offline   Reply With Quote
Old 09-15-2019, 07:15 PM   #39
johndhagan
City & State: Philadelphia, Pennsylvania
My Country: USA
I just joined the board to thank everyone who contributed the information on the failed C40 & C41 capacitor issue. After replacing them, I can report that three more APC Back-UPS RS 1500 units are back in operation!
Now I have to plan on replacing those sickly capacitors on three more APC Back-UPS RS 1500 units I have deployed and still working that haven't failed yet--but undoubtedly will soon.
Thanks again to everyone for saving us TONS of time finding the cause.
johndhagan is offline   Reply With Quote
Old 11-10-2019, 05:07 AM   #40
sundance
City & State: Bucharest
My Country: Romania
I also joined this board just to say "thank you"!
My RS 1500 is great and integrates perfectly with NUT on Linux. I bough over the years many other products from other manufacturers but none pleased me like this old APC.
Until one day... when is stopped to go online. I tried everything (circuit break, hardware reset the unit, software reset the front panel with NUT, set the tolerance to low, replaced batteries). Nothing worked. Even if plugged on AC power (230V) it wouldn't go online but on batteries. Sometimes was charging batteries (even if not going online), other times will discharge the batteries in the same conditions (plugged to AC). Some times it went online, but if AC power was lost and come back it will not go online again.
I monitored the parameters (with NUT) and saw that parameter "input.voltage" was erratically changing from 184V to 92V, 144V... etc. I mounted a meter and saw that the AC voltage was constantly 228V, so the UPS was a complete mess.
A nightmare. That is why I bought several other products... but not being satisfied I decided this Sunday to play with my old buddy.
And I found this thread! I opened the unit and saw that C41 was already manually replaced (with a higher voltage one). I bough the unit as new and nobody opened it ever. I replaced C40 and yupppyyyy! now everything works! I used a 50V one to prevent it from burning again too soon... maybe it helps.
I noticed that the marks for the polarity on motherboard are reverse to the ones on the capacitor (check attached). That is the "+" sign on the motherboard goes with "-" sign on the capacitor. I am not a specialist but I noticed this on the replaced one and I did the same.
I didn't had a hot air tube to heat the old damaged capacitor in order to remove it so I just cut it off with a clipper.
Thank you again for this common effort!
sundance is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2020
Powered by vBulletin ®
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
