Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Game Consoles & Other Weird Devices
Thread Tools Display Modes
Old 05-22-2018, 09:05 AM   #1
mikay786
City & State: Leeds
My Country: UK
I'm a: Knowledge Seeker
Default PS4 Not Reading Disks
Got a issue with my ps4 where it isnt reading disks, makes a whinny noise like it constantly accelerating and slowing down over and over again.
Anyhow i originally replaced the laser, no good.
Thought it might be maybe the motor in the drive so just replaced the entire laser deck.
Still no luck doing the same thing.
PS4 is the newer CUH-12xx model.
Any suggestion would be welcome, before i throw anymore money at it!
mikay786 is offline   Reply With Quote
Old 05-22-2018, 10:12 AM   #2
stj
stj's Avatar
City & State: Europe
My Country: some shithole run by Israeli agents
I'm a: Professional Tech
Default Re: PS4 Not Reading Disks
so you replaced the entire sled assembly & frame?
all that leaves is the pcb isnt it?
unless there is a problem with one of the rubber shock-mounts putting it at an angle.
stj is offline   Reply With Quote
Old 05-22-2018, 10:33 AM   #3
mikay786
City & State: Leeds
My Country: UK
Yes the metal frame and sled assembly, this
https://www.ebay.co.uk/itm/NEW-PS4-4...72.m2749.l2649
Mines the newer model drive that doesnt have a PCB. Could it be the PSU not supplying enough juice?
It does read and recognise disks to a certain stage, but when you try to play the game it give the unrecognised disk error.
Old 05-22-2018, 11:06 AM   #4
petehall347
City & State: worcester
My Country: United Kingdom
did you remove the solder blob on the new laser ?
wont be that as you say it reads .
petehall347 is offline   Reply With Quote
Old 05-22-2018, 02:05 PM   #5
stj
stj's Avatar
could be bad power rails from worn caps i suppose.
but it's a bit new for that.
Old 05-22-2018, 02:33 PM   #6
mikay786
City & State: Leeds
My Country: UK
What solder blob? I assumed it was just a swap in and out?
Old 05-22-2018, 02:35 PM   #7
mikay786
City & State: Leeds
My Country: UK
Yea it is a bit new for that, watched a video and the guy was saying itís this
https://m.ebay.co.uk/itm/For-Sony-PS...72.m2749.l2649
That causes the issue. Another motor in it, might be it as the whining noise sound like a motor struggling.
Old 05-22-2018, 04:13 PM   #8
petehall347
Quote:
new lasers have a solder blob that needs removing before it will work .. you said its working so maybe not all new ones have it . all the ones i have done have had the solder blob . caught me out once as forgot to remove it . wont read at all if its there .
Old 08-11-2018, 12:42 AM   #9
ngth82
City & State: Vancouver, WA
My Country: USA
Line Voltage: 120VAC 60Hz
I'm a: Hardcore Geek
If you still have this drive: make sure all the cables are reconnected to the drive (internally and externally). Otherwise, the drive revs up and down.
With regards to the solder blob: depends on when/whom you purchase them from. I've purchased lasers from 2-3 different eBay sellers, but sometimes they have it, sometimes they don't... can you post pics?
__________________
-Thomas
I'm a hardware engineer focused on networking equipment for my day job. I void warranties and fix consumer electronics for fun.
ngth82 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2020
Powered by vBulletin ®
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
