Badcaps.net Forum
Go Back   Badcaps Forums > Motherboards with Bad Capacitors > All Others Motherboards
Thread Tools Display Modes
Old 03-24-2015, 04:23 PM   #1
ThunderBob2011
ThunderBob2011's Avatar
Default Zotac 750a Capacitors
Hi all.
I am fairly new to replacing the capacitors on motherboards and wondered if anyone could let me know which caps i need to replace the following 3 on the board in the title.
They show as
Teapo (Green and Gold colored)
1000uF
6.3v
SM105*c
10/08
A3T1
If anyone could spec out a complete board recap that would also be great.
__________________
ThunderBob
Newbie to Badcaps Forum
ThunderBob2011 is offline   Reply With Quote
Old 03-24-2015, 06:58 PM   #2
c_hegge
c_hegge's Avatar
City & State: North Coast, NSW
My Country: Australia
Line Voltage: 240V 50Hz
I'm a: Professional Tech
Default Re: Zotac 750a Capacitors
Is this your board here?
http://badcaps.net/forum/attachment....1&d=1427245082
What country are you from? And where do you plan on buying your caps from? That's going to have a big bearing on what options are available to you.
Assuimng you are in the USA, you could use these to replace the caps in question - http://www.badcaps.net/store/product...roducts_id=131
There appear to be some larger teapo capacitors there too, which I would recommend replacing, but I can't tell from that picture what capacitance and voltage they are.
__________________
c_hegge is offline   Reply With Quote
Old 03-24-2015, 07:06 PM   #3
ThunderBob2011
Thanks for the fast reply.
I am in the USA and that does seem to be my board (except it is blue and mine is brown)
Thanks for the info on the caps. The bigger caps are 1500uF 16v.
Would these work?
Thanks again
Old 03-24-2015, 08:02 PM   #4
c_hegge
c_hegge's Avatar
They would, except it appears that they are out of stock. You can use these instead, though - http://www.badcaps.net/store/product...products_id=38
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
